Old 11-30-2017, 01:11 AM   #76
49chevy3100
49chevy3100's Avatar
Re: Finally my 49 s10 frame swap ls1/t56
Figured it out so comes to figure out it’s not a 95 it’s wither 93-94 so it’s a non pwm 4l60e I’ll have to double check my pcm pin out and fix any issues but comparing them they seem the same I’ll double check it in the AM
49chevy3100 is offline   Reply With Quote
Old 12-18-2017, 10:47 PM   #77
Joe Pass
Joe Pass's Avatar
Man you got a project....watching from Windsor
Joe
Joe Pass is offline   Reply With Quote
Old 12-18-2017, 10:55 PM   #78
49chevy3100
Yea haven’t had time to update I will be posting pictures hopefully tomorrow finally got frame welded up and harness almost done just have to tape it up so it looks finished up and going to start mock up on body so I can make the body mounts and remove everything weld up body mounts paint frame and install engine and keep on moving not much time to get stuff done with the holidays around the corner
Old 08-16-2018, 12:37 AM   #79
49chevy3100
Update: sold motor/ trans combo collecting my penny’s to finally bite the bullet for the LS style motor 4.8,5.3 or the 6.0 will most likely do the car I take instead of truck intake so I can have the corvette coil covers since that gives an awesome engine bay appearance. Started the body mounts today haven’t really had time to work on her due to unfortunate events and having surgery now that I’m fully recovered hopefully see this moving along . Will weld up the mounts tomorrow to finish those up then mock up the cab looking to do 6” off the top of the frame, from looking at other members project I think that should work well plan to bag it in the future, just want to get it running for now.
Old 08-18-2018, 02:06 AM   #80
49chevy3100
Here’s a picture of my almost fished cab mounts basically copied Hussey’s design from his Alberts build I’m basically going off his build extremely helpful so much detail and many pictures. Really thankful for everybody’s builds and pictures really helping me with this project my first build from scratch basically.
http://67-72chevytrucks.com/vboard/s...=664837&page=3
Old 08-18-2018, 11:05 AM   #81
joedoh
joedoh's Avatar
looks good, progress is progress!
Old 08-19-2018, 07:59 PM   #82
49chevy3100
Went to look at a 5.3 engine today a friend swapped out to install a 6.0 paid 75$ he dropping it off tomorrow it’s missing all accessories but comes with intake manifold can use for mock up for now and have parts coming in for upgraded dual valve spring and valve seats rockers basically full head valve train upgrade
Old 08-19-2018, 08:25 PM   #83
gigamanx
What a deal! Might have to buy him some beers to go with that 75 bucks.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 08-20-2018, 12:02 PM   #84
49chevy3100
Engine got dropped off today. He let me keep his engine stand which rocks due to having wheels for moving engine around.
Old 08-22-2018, 11:01 AM   #85
49chevy3100
Ripped into the engine yesterday couldn’t wait, took the heads off pistons look like the dish 5.3s but have stamping on them never seen that before anyone know what they are?
Old 08-22-2018, 12:55 PM   #86
OutlawDrifter
Might I ask why you're planning on dual valve springs? Are you running an aggressive high lift cam (like .625"+)?
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 08-22-2018, 01:04 PM   #87
49chevy3100
Do plan on getting a bigger cam for turbo set up not sure which one yet maybe one from Brian tooley racing. But want to make sure heads are ready to go.
Old 08-22-2018, 01:22 PM   #88
OutlawDrifter
Dual springs wear faster, just food for thought. You can get beehives that will easily support .600" lift, I'm running a set in my Z28, and the cam is .595/.585 and 230/232 duration. I wanted to avoid having to change springs every 10k miles, 40k+ on a set of beehives appeals to me much better.
Not trying to derail your vision, just playing devils advocate.
I left the LQ4 in my '49 is bone stock(aside from intake setup). It idles great, has fantastic street manners, and is dead reliable. I went overboard on the Z28, the clutch is probably the worst part, it's in or out, no slipping it. Not fun in stop and go traffic.
In all the BTR cams I've looked through, I want to try the Level/Stage 2 Truck Cam. Can still use a stock stall converter, LS6/LS2 valve springs, stock push rods, and it has just enough "lope" to know it has a cam. I think a 5.3 with a set of 243/799 heads and a Level 2 Truck Cam would be a fun cruiser set up. Lots of low to mid range torque, and near stock drivability and reliability.
1991 Z/28, 6.0L/T56
Old 08-22-2018, 01:31 PM   #89
49chevy3100
Will definitely look into that, coming from building fast turbo Hondas always used dual valve springs never had an issue so that’s why I was looking into dual valve springs set up will see what I can manage to buy tryna keep it low cost but building an engine is never cheap haha
Old 08-27-2018, 11:18 PM   #90
49chevy3100
Took out the cam rollers out today super sludged up but all looked good no marks and camshaft looked great well from what I could see by looking down got looks of cleaning to do still. Piston walls still have cross-hatch marking so maybe piston stamping from it being rebuilt at some point
Old 08-28-2018, 09:39 AM   #91
OutlawDrifter
I have pulled numerous LS blocks apart with 130k+ miles on them that still had perfect crosshatch in the bores.
1991 Z/28, 6.0L/T56
Old 08-28-2018, 09:43 AM   #92
49chevy3100
Only reason I mention maybe rebuilt pistons look like the 5.3s but mission the T marking in the middle and they have numbers stamped into it but nothing clear comes up when googled just two websites for turbo pistons
Old 09-02-2018, 01:37 AM   #93
49chevy3100
More engine photos more sludge, was able to pick up some parts from a local for cheap alternator bracket 2 complete intake manifolds stock exhaust manifols and power steering pump ac pump with bracket
Old 09-03-2018, 09:41 PM   #94
gigamanx
Call Mike Rowe. That's a dirty job!
Old 09-27-2018, 06:40 PM   #95
49chevy3100
I got a lot of parts cleaned and prepped for paint valve covers,oil pan, timing cover. I got the oil pick up tube cleaned and Windage tray cleaned won’t be painting these also have the heads cleaned out, haven’t ripped into the block yet. I did manage to finish the cab mounts and get them spot welded onto the frame will be getting the 2x1 inch square tubing later today to finally test fit the cab and fully weld in the mounts. Will post pictures later today
Old 09-29-2018, 01:54 PM   #96
joedoh
joedoh's Avatar
oof you need a big ultrasonic machine full of diesel for that sludge. maybe fill a 55 gallon drum halfway and bolt a washing machine motor with an offset bolt on the shaft so it vibrates, and just let it run for a week haha.
Old 09-29-2018, 03:29 PM   #97
dsraven
i'm sure you know already but keep the lifters in order so they go back in the same place, they get "sister'd" with a wear pattern to the cam so to prevent premature wear when assembling it is a good idea to keep the lifter in the same hole. a piece of 2x6 with some holes drilled to fit the lifters works pretty good, just remember to mark front
oven cleaner and hot water (after sitting with oven cleaner for a bit) works pretty good for sludge but don't get it on any bearings that you will be using again.
Old 10-09-2018, 01:23 AM   #98
49chevy3100
Yea too bad the heads where already taken apart when I got the engine I recieved a box full of parts push rods, lifters and coils so just thinking if I should just get all new parts or just go ahead and just reuse em all they hardly have any markings
Old 10-09-2018, 01:28 AM   #99
49chevy3100
Finally got cab test fitted cab sits high enough that I will have room to weld them in
Old 03-05-2020, 03:51 AM   #100
49chevy3100
Back again, the 5.3 is all finished up plans changed on the t56 will be doing a AR5 transmission out of a 2007 Colorado 5 speed fabbot sells the kit that allows you to use the 4l60e bell housing to mount up the transmission to a LS style engine. So far cleaned up front half of the frame primered and painted, installed brake booster and lines installed the ford 8.8 rear end bleed the brakes all working fine, installed the wilwood clutch pedal. Mocked up engine, mocked up steering column will have to move 2” to left since some how I missed that while reading the S10 HOW TO. Already have radiator support made will have to lock up and redo mounting since I changed my mind about the front bar style mount and will do the side mount instead.
