Old 08-28-2018, 02:33 PM   #1
plowro8
Oil pressure gauge
So before I installed my new engine, I had oil leaking from the back side of my oil pressure gauge. When I installed the new engine I replaced the copper line from the engine to the gauge and got the fitting nice and snug on the back side of the gauge. Well, it still leaks, which sucks because it leaks down my dash and drips onto the passenger floor, right where I am getting ready to install new carpet. My question, has anyone seen the actual gauge leak? Like maybe I need a new gauge, or is it more likely the compression fitting that goes into the back of the gauge?
plowro8 is offline   Reply With Quote
Old 08-28-2018, 02:47 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Oil pressure gauge
It may have the wrong fitting on the gauge end of the line. The gauge end of the line needs a compression sleeve nut to screw into the gauge. Here is what the fittings should look like. Can you post a picture of the line you bought?
LockDoc
Leon
Old 08-28-2018, 02:50 PM   #3
plowro8
LockDoc
I absolutely have the compression sleeve nut. The kit I bought only came with the other type, so I went to a good local mom and pop auto store and they had the compression nuts for the 1/8th inch line.
Old 08-28-2018, 03:07 PM   #4
plowro8
I just cant tell if it is leaking from where the oil line goes into the compression nut, or where the compression nut goes into the back of the gauge, or if it could possibly be the gauge itself.
Old 08-28-2018, 03:39 PM   #5
LockDoc
LockDoc's Avatar
I guess the only way you can tell for sure is to remove that gauge panel and inspect it while the truck is running.
LockDoc
Leon
Old 08-28-2018, 07:19 PM   #6
demian5
demian5's Avatar
Put yer phone back there and take a video while its doing it!
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 08-28-2018, 08:31 PM   #7
slomotion
Old Duffer
slomotion's Avatar
One other little tidbit.... too tight is as bad as not tight enough - it distorts the ferrule.
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 08-28-2018, 09:17 PM   #8
plowro8
That makes sense. It's really tough to tell where the leak is coming from because it's a very slow leak. It's kinda like having a plumbing leak under your sink, only you get one drip of water every 30 seconds, and you're checking every nut in the p-trap because it could be any one of them. I have tried watching it while it runs, but it doesn't show up. I think I will just replace the compression nut and clip the line back a bit and try again. If that doesn't fix it, probably a new gauge?
Old 08-28-2018, 09:32 PM   #9
HO455
HO455's Avatar
You may have to cut a 3/8" or so off the end of the tube. Before you put your new compression fitting on. Someone may have really reefed on it in the past and distorted the tube. Did that to myself many moons ago.
RIP Bob Parks.
