Old 08-27-2018, 05:23 PM   #1
MiraclePieCo
MiraclePieCo's Avatar
Speedo pulse generator speed sensor?
Trying to find a speed signal generator for my th350 with Dolphin electric speedo. Surprisingly elusive. Suggestions welcomed!
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 08-27-2018, 05:42 PM   #2
1project2many
Re: Speedo pulse generator speed sensor?
Reed type or sine wave? Pulses per revolution?
1project2many is offline   Reply With Quote
Old 08-27-2018, 08:39 PM   #3
mikebte
Something of this nature?
https://www.summitracing.com/parts/i...SABEgId2fD_BwE
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
mikebte is offline   Reply With Quote
Old 08-28-2018, 07:44 AM   #4
1project2many
I can't seem to find any instructions or specs, and it looks like there are several different models of gauges to choose from. There are a number of different types and models of sensor available. Two or three wires to the sensor can be used to determine sine wave vs reed type, but output voltage probably needs to come from specs. Number of pulses per revolution is also critical but without specs it will take a signal generator to work it out. Speed sensors are available from many different sources. Years ago I used United Speedometer in Riverside CA but it look like they're not the best choice anymore. The one linked from Summit may work but then again...
Old 08-28-2018, 08:03 AM   #5
mikebte
I’m not sure about Dolphin, but my speedo can be programmed from 4000-200,000 pulse per mile, 16,000 being the standard.
More info on your specific gauge will help.
May also consider the pulse generator offered by dolphin
https://www.dolphingauges.com/produc...ulse-generator
My YouTube:
Old 08-29-2018, 03:56 AM   #6
MiraclePieCo
Dolphin sells a GM pulse generator, so I ordered that. I didn't think it would work because my speedo has a 1-wire hookup to the sensor, but the sender has 2 wires. They said just hook either wire to the speedo and the other to ground.
Really the only reason I need a speedo is to fill the hole in the dash. The new cell phone speedometer apps are free and they look cool too. I used DigiHud on my last hot rod.
