Re: Rear Sway Bar
I recently installed the same sway bar on my 62. I mounted the bracket on the trailing arm with 1 bolt on either side of the seam. Its the only way i could see to make it fit. As for the end links, mine were too long also. I replaced the bolts and eliminated the spacer. The kit comes with a 90* bracket that would have worked perfectly if the sway bar was a few inches wider. They missed out on a simple solution to accommodate any amount of drop if it was wide enough to use those L brackets. This is the only picture i have, prior to replacing the end link bolts
