Nv4500 or nv3500?
I know this question has been asked quite a bit. But which trans is a better swap? And what do I need to make the swap. I have a 1979 k20 and I already have the pedals bellhousing and reservoir off of an 87 donor. And has a np205. What all else is needed for this swap? And which is better?
Posted via Mobile Device |
![]() Join Date: May 2015
Re: Nv4500 or nv3500?
the 45 is defiantly the better of the 2
the 35 was used in compact and light trucks the 45 was used in heavy trucks.... ive got 2 45s and I really like em in a k truck youll need the 4wd version unless you run divorced t-case
#3 | |
not 100% certain but..from the engine back....
bellhousing clutch p-plate flywheel throwout bearing....is your bellhousing for a hyd throwout bearing or clutch fork? 4wd nv4500 adapter from nv4500 to np205.. youll probably have to move x-member and possibly shorten and lengthen d-shafts
this may help.....http://67-72chevytrucks.com/vboard/s...d.php?t=373510
The bellhousing that I have is for a hydraulic clutch off of a sm465. Will that work? Does it matter which Nv4500 I use? Like the GM or dodge one?
Nv won't bolt to your bellhousing...you'll need the nv bellhousing...dodge version won't fit the Chevy unless you change the input shaft...the Chevy uses a pulse style Speedo output,the dodge uses cable speedo....
Chances are the 205 from 79 is a figure 8 pattern and not round like a 4x4 4500. Also, the (GM) 4500 has a 32 spline output and only TH400 205s have a 32 spline input. Changing to 32 spline input requires machining the TC case for a bigger bearing.
There might be adaptors to get around the bolt pattern. Try ORD, NWF, etc. Advance adaptors has a conversion guide that should explain this. They can mail one or it should be downloadable. GM 4500s have a few variants. 93-94, 95 and 96 up if I recall. 95 had a few features from early and late. I seem to recall the early ones had a steeper low, no synchro on reverse and a different (normal GM) front bolt pattern. Forget the 3500 and spend some time researching the 4500. |
I'm a fan of the 3500, especially of you're just going to daily drive/wheel it. Drove a 97 on 35's and mild wheeled it no problems, dailies it for a Year. If you're going to really tow and and beat on it go 4500. But 45's are more expensive.
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
| Bookmarks |
