Old 08-29-2018, 06:18 PM   #1
bautino95
spray paint over POR15 for topcoat OK?
Thanks everyone for all the help I've been getting lately. I'm getting ready to POR15 my frame, trailing arm and rear-end. I know the por15 is not UV safe and I know it wont see that much UV on the frame ect… But was thinking about just using some Rust-oleum spray paint for a topcoat over the POR15. Will this work? Or would it be better to use this oil base brush on Rust-oleum paint? I'm gonna be brushing on everything on.
bautino95 is offline   Reply With Quote
Old 08-29-2018, 06:20 PM   #2
bautino95
Re: spray paint over POR15 for topcoat OK?
pics
Old 08-29-2018, 06:29 PM   #3
toolboxchev
I am not a paint guy but initially would think an oil base would be better, sprayed on of course.
I have used that Professional rattle can stuff on a rear bumper over SEM self etching primer and it has held up for a good 10 years. I of course scratched the crud out of my bumper.
toolboxchev is offline   Reply With Quote
Old 08-29-2018, 06:47 PM   #4
rockyrivermark
I heard por 15 now making a UV safe product now.
Not sure 100 but worth looking in to.
My frame is regular por 15. Couple years in still looks fantastic.
RRM
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 08-29-2018, 07:35 PM   #5
Red71gmc
I cannot definitely answer you question of spraying over por 15. However, if you find out it is ok then don't use Rustoleum. I had used rustoleum for years on semi frames and it fades and is a short life product. For a few dollars more use Valspar metal enamel. It holds color much better, last longer and covers exceptionally well. It's rustoleum on steroids.
Red71gmc is offline   Reply With Quote
Old 08-29-2018, 08:22 PM   #6
jonmc56
jonmc56's Avatar
It is my understanding that if you let the POR-15 dry completely, a topcoat will not adhere very well (unless you sand/scuff it to give it a tooth, or use a special primer). When I painted my frame I let the POR-15 dry to a very slight tackiness (the instructions called it a 'slight finger drag'), then used POR Chassis Coat Black in spots where I wanted a topcoat. In any case, I'd definitely give them a call and ask, it's too much work to have to do it over again if something doesn't adhere well.
Jon
'69 C10 CST
'68 Chevelle Malibu
My 69 CST Build Thread
jonmc56 is offline   Reply With Quote
Old 08-29-2018, 09:51 PM   #7
bautino95
well that took longer then i thought. got the first coat of por15 on, not gonna do the second coat till the morning, i know i should do the second coat while its still tacky, but im to tired at this point and wont be able to see the second coat go on at this point.
Old 08-29-2018, 10:22 PM   #8
bautino95
pic
Old 08-29-2018, 10:45 PM   #9
Husker
Husker's Avatar
I brushed it on my Jeep frame with the cheap brushes then used their overcoat UV 15 yrs ago still holding up. Cant see brush marks
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is online now   Reply With Quote
Old 08-29-2018, 10:55 PM   #10
dmjlambert
dmjlambert's Avatar
You probably only need one coat. But if you want another coat, this is from the instructions: "If the second coat is applied too late it will not adhere because of the slick surface and will peel."
Tomorrow you can use TIE-COAT PRIMER or ETCHING PRIMER that they sell at POR15, or sand/scuff as jonmc56 mentions. Then put another coat of POR15 if you really want it, or just put a primer and/or topcoat on of your favorite paint. I have had success with misting the POR15 with Rust-oleum spray can primer while the POR15 is still tacky, and then you don't have to do anything special.
I think for a frame, if it were mine, I would consider it 100% done if you leave it tonight and not do anything more with it.
http://por15bc.com/por-15.htm
Last edited by dmjlambert; 08-29-2018 at 11:00 PM. Reason: add link to instructions
Old 08-29-2018, 11:05 PM   #11
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
I just brushed mine on 2 weeks ago. 1 Coat, no top coat. I don't plan on having the wheels facing up so not concerned about UV. I did my Chevelle in 2002 the same way and it looked great still in 2014 when I sold it.
http://67-72chevytrucks.com/vboard/a...1&d=1535598082
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline   Reply With Quote
