Old 12-03-2014, 12:11 PM   #1
chevycowboy1985
94 frame under a 63 gmc
Well got lots of work done the past week . Did lots of research about this and everyone said don't but I had too. After finding the donor truck with new tranny and new clutch and motor that only has 10000 kms on it the battle began . It was not as tough as most would think worked out really good to Me.
chevycowboy1985 is offline   Reply With Quote
Old 12-03-2014, 12:38 PM   #2
Ronzo
Ronzo's Avatar
Re: 94 frame under a 63 gmc
Looks good, might have to pop over and take a look.
Ronzo is offline   Reply With Quote
Old 12-03-2014, 02:17 PM   #3
Ronzo
Ronzo's Avatar
Did you shorten the box too?
And, is that the cab I saw in your garage this summer?
I still need to grab those bezels for my stepside.
Old 12-03-2014, 02:22 PM   #4
chevycowboy1985
Ya that's the cab and yes I shorting the box but it's in real bad shape and found a couple different set I found
Old 12-03-2014, 02:26 PM   #5
Ronzo
Ronzo's Avatar
The stepside box will look good on there.
Old 12-03-2014, 09:08 PM   #6
lowlife4life
lowlife4life's Avatar
Looks good man glad it worked out for you!!!!
lowlife4life is offline   Reply With Quote
Old 12-03-2014, 09:51 PM   #7
chevycowboy1985
Ya worked out better then I thought it would just working on body mounts now
Old 12-04-2014, 09:54 AM   #8
Jeff La
Looks good. So what all did you have to do to make it work? I have been thinking about doing the same.
Jeff La is offline   Reply With Quote
Old 12-04-2014, 12:46 PM   #9
chevycowboy1985
Well the cab fit well plan on moving the front mounts back and shorting then by 1 1/4". The rear hole end up right over top of the frame ,have some work to do there. Rad support is about 4" off the frMe going to make custom mounts or use part of the 94 rad support to mine so I can use stock location. It's not as hard or bad as I thought it would have been. Going to post more pictures and info as I get more done this weekend
Old 12-04-2014, 01:28 PM   #10
Lokin4AReason
Lokin4AReason's Avatar
did any of the hole(s) line up or what kind of modification(s) needed to be on to settle the component(s) on that late model frame .... ???
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 12-05-2014, 10:23 AM   #11
Jeff La
I had thought about using the 94 mounts on the cab. Just cut the section of the 94 cab out where it's bolted in and weld to the floor of the 65 cab, that way I have the new bushings and can unbolt the cab from underneath. That would be simple even if you have to move the mounts themselves.
Old 12-05-2014, 01:49 PM   #12
Very Interesting. Can't wait to hear more on this!
Palf70Step is online now   Reply With Quote
Old 12-08-2014, 05:00 PM   #13
Ronzo
Ronzo's Avatar
Can you lower that frame and suspension easily?
Make any progress on the weekend?
Old 12-08-2014, 11:51 PM   #14
chevycowboy1985
Ya can get stuff way easier and got the cab mounts all finished up will get some pictures up tomorrow
Old 12-16-2014, 07:58 PM   #15
Ronzo
Ronzo's Avatar
Pics?
Old 12-23-2014, 07:28 PM   #16
chevycowboy1985
got some pitures front mounts are off the new frame just cut down and moved back. rear mounts are off the 63 frame just cut down to match angle and welded on top of the frame. im working on the rad mounts right now igoing to use the rad support off the 94 and cut it down to mount the 63 to it.
Old 08-18-2017, 12:56 AM   #17
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Any updates?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 08-18-2017, 08:34 PM   #18
PGSigns
PGSigns's Avatar
He last logged in more than 2 years ago. Be nice to know if it ever got finished.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-30-2018, 12:00 AM   #19
LostMy65
LostMy65's Avatar
4 years later bump.
Sure wish you'd post how it all came together.
