Almost Satisfied
![]() Join Date: Mar 2002
Wiring Question
I have been doing searches on the page, but not really finding what I am looking for. I know I need to re-wire my LS harness for the motor, but what harness do I need for the truck itself? If I buy a stand alone for the motor/transmission what harness is best for the truck and the LS tie in? I looked at the American Auto Wire harness for our trucks, but it seems like I don't need a bunch of those wires. Confused on the best way to go for the LS and truck together and not spend an arm and leg.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
![]() Join Date: Aug 2012
Re: Wiring Question
The LS harness is usually stand alone. It doesn't tie in with the rest of the truck. You can either replace just the truck wiring that needs to be replaced or completely rewire the whole truck.
American Auto Wire sells what they call the Factory Fit which is the original style wires. Some of them are pricey. If you need to replace very many circuits, the Classic update may end up being cheaper in the long run. M&H Electrical Fabricators also sells individual stock wiring. http://www.wiringharness.com/
Doug Old Build Thread - 383/T56 http://www.67-72chevytrucks.com/vboa...d.php?t=540838 Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua 5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital http://67-72chevytrucks.com/vboard/s...d.php?t=778784 |
Almost Satisfied
Re: Wiring Question
I need all the wires for the truck front to back. Wasn’t sure how things like the starter and alternator used both harnesses. I would assume they both do?
Re: Wiring Question
I used an AAW Classic update, I have really liked it so far. You do end up not needing most of the engine side of the chassis harness, but the wires are easily removed and only add up to like 6 or so wires that you remove. I like using a specific harness for the truck that way you get everything laid out in the prints, all the connectors are new and made for the application, the update series uses blade fuses, has 6 various power circuits that really come in handy for accessories like power locks, aftermarket gauges, power windows, etc.
Your truck wiring will need 12v from the battery, and the starter solenoid wire to start the truck. Thats really it from the chassis side of things. The engine will also tie into the positive starter terminal or battery, the engine runs the alternator cycling but your 12v power ties into the starter or the battery. The engine will also need to tie into keyed ignition power, brake light switch, NSS switch, and a couple others I cant think off the top of my head. Attached are a couple pictures, these are all specific to how I wired my own truck so there are Im sure several variables. Frist pic is the engine side of the chassis harness, 12v to my starter, and purple ignition wire to the starter solenoid. Tan is the brake pressure switch. Second pic is my starter, I ran most of my power off of the starter stud. From back(closest to engine) to the front. Black wire hard to see is the engine harness 12v tie in, 2 gauge cable from the battery, purple is starter solenoid from chassis, orange is 12v power from alternator, brown on the very bottom hard to see is the 12v tie in for the chassis. |
Almost Satisfied
Re: Wiring Question
Very helpful Sprint. I appreciate it. So, in theory I could get my engine running before I ever put the cab and chassis wiring together.
Re: Wiring Question
Sprint im glad you posted that man. Im working on fuel system now and then wiring so hopefully ill be doing that within the next few weekends.
I want to ask you a couple questions to verify im not going to screw this up. The purple wire in your pics goes from the fuse block bulk head to the small bolt on the starter and the big read wire goes straight to the battery? |
#7 | ||
Re: Wiring Question
The big red wire on the bulk head goes to the 12v battery side of my starter. It's the brown wire in the post above, it switches to brown as on the starter end is a fusible link. I choose to run most of my 12v battery power from the starter stud to clean up the battery connections. |
![]() Join Date: Dec 2015
Re: Wiring Question
Ok I'm going to keep an eye on this thread .
#9 | |
Re: Wiring Question
Purple wire is from ignition to bulk head to starter small bolt. Did you use a fusible link here also? The red wire from the fuse block goes to the large bolt on the starter with a fusible link and this powers your PCM ? The large 1 gauge wire coming off the large bolt on the starter goes directly to the battery? |
#10 | ||
Re: Wiring Question
Yes |
Re: Wiring Question
Ok thanks! Thats about how is exactly how I plan to wire mine.
Did you put any inline fuses on your engine harness? |
Re: Wiring Question
Re: Wiring Question
Ok thanks.
| Bookmarks |
