Block cleaning after machine shop work
Picked my block up today (sbc 327) from the machine shop..hot tanked, bored .030, cam bearings are installed and all freeze plugs and other plugs installed as well..what is the process everyone uses for final block cleaning before paint and assembly?
![]() ![]() Join Date: May 2015
Re: Block cleaning after machine shop work
If they did all that they should have it very clean...I'd wipe the outside down with wax and degreaser..then prime and paint
Don't paint your gasket surfaces...
![]() Join Date: Dec 2009
I use (ether) AKA starting fluid.
If it is clean there will be no residue. Or Carb cleaner will let you know if they cleaned your block (Good).
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
I like brake parts cleaner for degreasing.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Soap and water works before assembly.
