Old 09-01-2018, 07:12 PM   #1
Domingo
Quadrajet fuel leak
Today was the day. Finally got all the parts to start the engine and break in the cam. Ran it for 20 + minutes at 2000+ rpms. Now my issue when i was adding some fuel to carb with a small bottle the fuel was coming out the base of the carb it looks to be coming out of the primary butterfly shaft is this normal on qjets.
Domingo is offline   Reply With Quote
Old 09-01-2018, 07:38 PM   #2
100%Chevy
Re: Quadrajet fuel leak
Yes,it happens when you pour gas in like that.
Open the throttle plate some before pouring it in.This lets it go on down before it can puddle on the the plate to run out around the shaft.
And,the more worn the shaft is the worse it will run out.
After it's running,check for leaks.
Mike.
100%Chevy is offline   Reply With Quote
Old 09-01-2018, 08:07 PM   #3
Domingo
Thank you.
Old 09-02-2018, 02:16 AM   #4
mike16
good point- worn shafts- thats a hint that you may experience vacuum leaks through those same worn shafts.
mike16 is offline   Reply With Quote
