![]() Join Date: Sep 2001
possible to swap cabs with engine in?
The bed is off and the front end is removed but I wonder if I can get away without pulling the engine. Too risky? ![]() |
Yes you can do it, just lift it straight off, and make sure the firewall dosen't hit the dizzy. I did it...
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
its all about the +6 inches
Just remember to remove anything that connects the cab to the frame, like master cylinder, harnesses ect... pick it up, and pull it back as soon as you can to gain more "swaying room" and you'll be OK.
