Closed Thread
Old 08-29-2018, 09:59 AM   #7201
Jim Boy
Re: What did you do to your truck today? Chapter II
Thanks for the tip. I'll get in touch with them and ask a lot of questions. Enough on the computer, get working on the beast.
Jim Boy is offline
Old 08-29-2018, 08:55 PM   #7202
ZEKE68
ZEKE68's Avatar
Got my new wood bed installed.
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline
Old 08-31-2018, 05:18 PM   #7203
rsgt
rsgt's Avatar
Replaced my burned up ignition switch and wire connector. My truck would not start anymore. Oreily's had the parts in stock.
rsgt is offline
Old 09-01-2018, 02:02 AM   #7204
Patch
Patch's Avatar
Engine out.....drum brake front end down. Got some clean up accomplished and some rust conversion sprayed. The last cross member bolt......the LAST one.....broke on me....lol. Pry bar and gravity and she dropped. Found the coil to still be original GM as well.
Patch
Patch is offline
Old 09-03-2018, 06:33 PM   #7205
66clow
66clow's Avatar
Good day today. Installed copper wire to get my oil pressure guage working. Replaced the master cylinder. Installed overflow bottle and new grille.
66clow is offline
Old 09-03-2018, 08:31 PM   #7206
tdangle
tdangle's Avatar
Scored a stock 2004R 2-3 servo assembly for my trans from Pick a Part to downgrade the super servo that the local trans builder put in and then keep putting me off to fix my issues. I guess he thought i was wanting a 1/4 mile truck as the shifts up were very harsh and the 3-2 downshift was absolutely horrible. The sound of the clunk made it sound like I was going to drop the rear end everything I slowed to a stop.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline
Old 09-03-2018, 09:13 PM   #7207
Barnfind46
Barnfind46's Avatar
Finally got the replacement parts installed from the near accident on Mothers day this year. My u-bolt on the lower control arm snapped when I was turning off a two lane highway and sent me,my wife and my camper into oncoming traffic. Got it stopped and no one was hurt. Truck got a bent upper control arm and inner tie rod.Got the truck home and it has sat till now.Pictures are of the right side but I had already done the left.
68' with no bells or whistles unless I add'em.
Barnfind46 is offline
Old 09-04-2018, 09:54 PM   #7208
Patch
Patch's Avatar
Got the front suspension cleaned and painted and installed this weekend! Very little blood was involved.....
Patch
Patch is offline
Old 09-05-2018, 08:50 AM   #7209
Ekliptix
Ekliptix's Avatar
drove it to work for the first time in a year
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt.
Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD.
Ekliptix is offline
Old 09-05-2018, 10:29 AM   #7210
Jim Boy
Smile Re: What did you do to your truck today? Chapter II
That truck belongs in Ontario. Too nice for the west to appreciate. Nice job! Have a good one eh.
Jim Boy is offline
Old 09-05-2018, 10:40 AM   #7211
Ekliptix
Ekliptix's Avatar
pft, don't be a hoser. West is Best.
Ekliptix is offline
Old 09-06-2018, 09:43 PM   #7212
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I've been ready to install the engine cross-member for weeks pending another hand. Last night I was feeling a little alone, go figure my son shows up out of the blue. We maint. his car, then slapped on the cross-member.
Hurry up and wait is the theme. Can't finish my engine pending the painter for my oil pan. Can't install the rear leafs pending new bolts, and I didn't account for reusing the U-bolt plates, pending powder coat. Can't do the front suspension because new drop spindles come unfinished.
Always plenty to do however, methodically adding what I can to the frame, parts org. So many parts. PARTS REDUCTION ........I'm reusing most of the original hardware, no fun chasing them down.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 09-06-2018, 10:12 PM   #7213
chuckTN6772
Talking Re: What did you do to your truck today? Chapter II
New wheels and tires today!!!!! Ridler 695s 22x9 5inch backspace. 265/35tires. Now to get the truck sitting a little lower!!!!
chuckTN6772 is offline
Old 09-07-2018, 12:33 AM   #7214
weq92f
weq92f's Avatar
...hoser...
lol
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline
Old 09-07-2018, 12:35 PM   #7215
3757chevy
3757chevy's Avatar
Nice , Welcome aboard.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline
Old 09-07-2018, 02:24 PM   #7216
RodnRudy
RodnRudy's Avatar
Very nice! Nothing like some bling to help the build along.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline
Old 09-07-2018, 11:48 PM   #7217
ZEKE68
ZEKE68's Avatar
Got my engine running after a year of working on it and the rest of the install. Fixed a transmission cooler line leak, and two fuel line leaks. The thing sounds good. On the bad side it looks like I have a seeping leak on the pinion seal, which I put in when I rebuilt the rear. That means taking the rear completely apart again to replace the seal, and I have the new bed wood installed. Bummer.
ZEKE68 is offline
Old 09-08-2018, 03:00 PM   #7218
VWNate1
VWNate1's Avatar
The GM Dealer training taught us to replace pinion seals in place.....
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 09-08-2018, 03:37 PM   #7219
ZEKE68
ZEKE68's Avatar
How did you set the pinion preload without pulling it apart?
ZEKE68 is offline
Old 09-08-2018, 03:47 PM   #7220
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today? Chapter II
What you do is : mark the position of the pinion nut relative to the shaft and re torque it to *exactly* the same position it was before you took it apart .
Those who lack experience will claim it's not the same and won't work etc. , those who've done it and never had a comeback, leak or failure over decades and 100,000's of thousands of miles, know better .
-Nate
Geezer
VWNate1 is offline
Old 09-08-2018, 04:18 PM   #7221
84yotamann
Well for my first post ever I thought I’d share, long story short I traded a buddy work for doing a cab swap for a 67 LWB 2wd 4spd. It has a 6lug on front end which I would assume is factory and a full float Dana 60 8lug in the rear with leafs. I left work a little to happy on a Friday and grenaded the rear end. So I got a full rolling 74 chassis with SBC th350 2wd lwb. My plan is to swap the 12bilt into the 67 along with all the front suspension components to make it 5lug all around. Also I will put the th350 in it once I pull it and rebuild it.
So i finally got around to pulling the rear end and pressure washed it. Pressure washed the th350 in the chassis and it will get pulled next. Started measuring leaf spring lenghts and found I can not swap leaf spring due to length and spring width 😟. And I need a new driveling because the 60 had a 1350 ujoint and 12 bolt is 1310 I believe.
And if anyone could help me identify which trans this is would be very helpful.
2008 GMC 2500HD 6.6l Duramax Diesel
67 GMC long bed 2wd my "main squeeze"
85 Toyota project, SBC, TH350, D60 front, D70 Rear, 3 linked Front, 4 link Rear.
43 Willys, family heirloom
84yotamann is offline
Old 09-08-2018, 05:01 PM   #7222
ZEKE68
ZEKE68's Avatar
I may try that. I think I tried to drive the seal in too far. Brain fart moment. Still have to get the torque on it under the truck though.
ZEKE68 is offline
Old 09-08-2018, 06:08 PM   #7223
3757chevy
3757chevy's Avatar
Originally Posted by 84yotamann View Post
So i finally got around to pulling the rear end and pressure washed it. Pressure washed the th350 in the chassis and it will get pulled next. Started measuring leaf spring lenghts and found I can not swap leaf spring due to length and spring width ��. And I need a new driveling because the 60 had a 1350 ujoint and 12 bolt is 1310 I believe.
There is a u joint that is 1310 on one cross and 1350 on the other so you don't have to change your driveshaft. Napa #UJ348 or spicer 5=460x.
MIKE
Old 09-08-2018, 06:18 PM   #7224
Lanman1972
Lanman1972's Avatar
Made a rack to hold a door and fender for paint.
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White
1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White.
Lanman1972 is offline
Old 09-08-2018, 06:27 PM   #7225
72LB
72LB's Avatar
Replaced the motor and transmission mounts to polyurethane mounts. Man what a difference,
1985 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline
Closed Thread
