Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 08-29-2018, 07:23 PM   #1
pwdcougar
pwdcougar's Avatar
Champion Spark Plug Cleaner
Just picked up this little Champion spark plug cleaner. I know plugs are cheap for the most part but I do a lot of small engine jobs and figured I'd give it a try. Any ideas as to what media to use in it? It had a mix of sand and black beauty like stuff in it. Would glass beads be too fine?
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 09-04-2018, 08:49 PM   #2
VictoriaHardware
VictoriaHardware's Avatar
Re: Champion Spark Plug Cleaner
Glass beads will be perfect. Sand or Black Beauty are too coarse.
VictoriaHardware is offline   Reply With Quote
Old 09-05-2018, 08:24 PM   #3
pwdcougar
pwdcougar's Avatar
Thanks!
Paul
Old 02-06-2019, 03:31 PM   #4
sick472
sick472's Avatar
I have alsways wondered about bead blasting sparkplugs...wouldn't you run the risk of gettting beads stuck "up in there" that would eventually end up in the cylinder?
I have heard of blasting plugs often enough just never had the nerve to do it myself. Wire brushes, bench grinder wire wheel, and some brake parts cleaner work fine when needed.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 02-09-2019, 12:12 AM   #5
truckster
truckster's Avatar
It's been decades since I used one, but I think the one we had in our shop used blast media first and then clean air.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is offline   Reply With Quote
Old 02-09-2019, 12:38 AM   #6
pwdcougar
pwdcougar's Avatar
The little unit I picked up has two buttons. One blasts the glass bead and the other just high pressure air. Before reinstalling the plug I always inspect it and take a close look at the inner insulator. It only gets used on small engine plugs though.
Paul
Old 02-09-2019, 12:53 AM   #7
RUN GMC
RUN GMC's Avatar
They are still used in the shops of airplane mechanics.............
https://www.aircraftspruce.com/catal...xoCADcQAvD_BwE
https://www.youtube.com/watch?v=98iztkS3OfI
RUN GMC is offline   Reply With Quote
Old 02-13-2019, 08:56 AM   #8
77c10bowtie
77c10bowtie's Avatar
When I was in highschool in shop class, back when schools still had shop classes, we had one of those and it was just glass beads followed by compressed air. Two button style like mentioned above. I would think anything more than glass beads would be too abrasive on the small gas engine plugs with such soft metal used.
77c10bowtie is offline   Reply With Quote
