Old 08-30-2018, 03:47 PM   #1
Chevystep
66 front disc brakes?
with ORIGINAL 15” 6 lug wheels.....does anyone make ‘em? My drums are fine and I’ve split the lines with a dual MC, but front discs would be nice and I know everyone raves about the difference, but my original wheels look really great all powder coated with the original hub covers painted up. I had hope that Scarebird’s kit would work, but they said their original fab job was from a 66 panel truck with 16” 6 lug wheels and say the calipers will hit on original 15” 6 lugs. They don’t hold out hope that they’ll fab up a disc conversion that will work on 15’s, although it would seem THAT would be the most prevalent model out there!
Chevystep is offline   Reply With Quote
Old 08-30-2018, 04:48 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: 66 front disc brakes?
Do you have a photo of the backside of your front wheels?
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-30-2018, 06:40 PM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
There's a thread here that debates this topic - Disc vs Drums.
If you have drums adjusted correctly, and you skid in a straight line, how will discs help you skid better?
I have drums all around with a dual pot MC . I've been putting off switching to discs for easily 4 years now.
Have you thought about putting on a vacuum booster for power drum brakes?
Because, I think that's why some think discs made the difference, but when it could very likely be that they added power to their brakes when they went to discs.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 08-30-2018, 10:59 PM   #4
luvbowties
luvbowties's Avatar
Smile Re: 66 front disc brakes?
You asked, "If you have drums adjusted correctly, and you skid in a straight line, how will discs help you skid better?" Where discs outperform is when you have to "skid" several times back-to-back/or stop where brakes must be applied for a long period of time : drums-and-shoes get hot very quickly and 'fade', giving you NO stopping power at all; discs avoid such quick fading. After 'fading' thru an intersection at the end of a high speed run, showing my a** to 4 friends riding with me what it would do on top end, our combined weight and drum brakes just would not stop AT ALL! **Otherwise I could follow your logic and loved your term "skid better".
This was in the sixties when I was younger and foolish'er and downright DUMB--not to mention being highly embarrassed.
Sam
luvbowties is offline   Reply With Quote
Old 08-30-2018, 11:53 PM   #5
LostMy65
LostMy65's Avatar
Sam
Ok fine! So you can skid with style.
Old 08-31-2018, 09:24 AM   #6
Chevystep
Well, I don’t think there is any doubting the technology and performance advantage of discs v drums. But my truck still stops, and one does have to adjust and be alert that stopping distances and times are a little longer. But my other car hobby is Model T’s (3 pedals, 2 hand levers to drive it, 3 levers if you count the parking brake), so having to stay on my toes while driving my hobbies is no problem. I guess they make similar 15” 6 lug steel wheels that work with discs, but having to buy and powder coat 3 more is a pain in the wallet....more research is needed....
Old 08-31-2018, 09:34 AM   #7
LostMy65
LostMy65's Avatar
Vin63 asked if you had a pic of the backside of your wheel.
Old 08-31-2018, 12:20 PM   #8
vin63
vin63's Avatar
Oh, well. Just in case anyone else runs into an issue of a drum brake-type wheel that the back of the wheel is tapered to the center, but would like to keep the wheel center when switching to disc brakes...I have, in the past, used a local steel wheel place to swap the centers to a newer disc brake-type rim. Usually, I can also request a particular backspace dimension at that time. This was important for a few customers not only using a full wheel cover, but especially the ones using a specific poverty or hub cap. A lot of steel wheel repair and custom wheel places offer this service.
Old 08-31-2018, 06:29 PM   #9
Chevystep
Sure....two inside picts..
Old 09-04-2018, 11:18 PM   #10
LostMy65
LostMy65's Avatar
From another thread :
Originally Posted by theastronaut View Post
I used bolt on spacers on the front of my old '66 since I had already repainted the wheels to match.
