Old 09-06-2018, 04:36 PM   #1
72farmer
LMC door glass is too thick
I just got a order in from LMC. It included a LH door door glass for my 87 chevy truck. Part # is 38-6100 it is the correct number but the glass is .210 thick. I know the older squares had thicker door glass. I measured my old original glass and it is .145 thick. Can I use this thicker glass if so what kind of problems can I expect? Has anyone ever had this problem with LMC?
72farmer is offline   Reply With Quote
Old 09-06-2018, 05:28 PM   #2
rickit
rickit's Avatar
Re: LMC door glass is too thick
think I just figured out my problem, I just did a complete interior overhaul everything new,even new glass and regulators that came from lmc the windows are very hard to roll up and down guy that did the work said everything was adjusted right , maybe its the glass?
rickit is offline   Reply With Quote
Old 09-06-2018, 05:54 PM   #3
72farmer
Glad I shed some light on it for you. I also have a 71 that has LMC door glass and it is thicker that original. They very hard to roll up and down also.
Old 09-06-2018, 06:25 PM   #4
geezer#99
geezer#99's Avatar
Check with a local glass shop and see if they can make you a door glass in the right thickness.
Years ago I had all new side glass made for a 56 bel air. Just supplied them with the old stuff so they could cut them perfectly.
Old 09-06-2018, 06:36 PM   #5
72farmer
Can't do that on squares the glass is curved.
Old 09-06-2018, 07:15 PM   #6
geezer#99
geezer#99's Avatar
Sorry!
My bad!
