05-12-2004, 01:30 PM | #1 |
one set closer
Sandblaster
I WOULD LIKE TO SEE PICTURE OF SOME SANDSLASTER AND WHERE DID YOU GET IT FROM. I'M THINKING ABOUT BUYING ONE IF THEY ARE NO TO MUCH.
05-12-2004, 02:35 PM | #2 |
maybe if you ask Dubie,he will send you one.Be sure and buy a pressure feed as the siphon ones waste too much sand.Depending on what you are doing it might be just as cheap to get someone to do it for you.
05-12-2004, 05:30 PM | #3 |
Check out this place http://www.tptools.com/ they even have a do it yourself kit.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
05-12-2004, 06:12 PM | #4 |
I need another Barley Pop
Just a sandblaster or a sandblasting cabinet? Here's my cabinet from I believe Northern Tools. Paid $299 for it.
67 Short Fleet 4x4 04 Honda CRF450R 89 Toyota 4-Runner 34 Ford 2 door sedan - Long term project ---------------------------------------------- There is a very fine line between "hobby" and "mental illness" |
05-13-2004, 02:11 AM | #5 |
The cabinet is the way to go for smaller stuff.
I built my own pressure feed blaster a couple of years ago and just got to use it for the first time about a week ago. Works good but I need a bigger compressor to keep up with it now.
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
05-13-2004, 07:05 AM | #6 |
Watch out for your cornhole !
I have two blasters. One is a cabinet type and the other is a pressure type. Both came from TIP tools (see link above in the other guy's post). This brand may cost a little more, but you won't be sorry.
05-13-2004, 07:32 AM | #7 |
Almost done!
I bought a cheap blast cabinet from harbor freight. About $100. The angle of the gravity feed hooper is not steep enough and you have to manually rake the blast media to the pick up tube. It is for sale! Will deliver.
The 1970 SWB Project Removed 6cyl manual trans, manual everything V8-350 Auto/PS/PDB Blazer Fuel Tank Behind the Marker Light Fuel Fill |
