Old 09-07-2018, 02:25 PM   #1
fightingcec246
Why is brake master cylinder empty?
I just returned from a extended stay way(12months) from home and had my truck in storage. Everything was fine with it, except when I checked my OEM master cylinder resevoir level - it was bone dry. I do not see any leaking around my brake lines to the drums. I am surprised as to this - I filled the resevoir back up, bled the brakes and "all is well" - or so I think. Is there anything I should be concerned for? It is puzzling that my resevoir was empty after the vehicle being in storage for 12 months. Is this normal? Or do I need to do more investigation and determine the culprit to the fluid loss. Thanks in advance.
fightingcec246 is offline   Reply With Quote
Old 09-07-2018, 05:45 PM   #2
old cruiser
old cruiser's Avatar
Re: Why is brake master cylinder empty?
just a thought. check firewall or floor possible leak at back of master cyl
old cruiser is offline   Reply With Quote
Old 09-07-2018, 06:07 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Oh you "need" to investigate.
Old 09-07-2018, 06:08 PM   #4
mongocanfly
mongocanfly's Avatar
X2....dont trust it..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
mongocanfly is online now   Reply With Quote
Old 09-07-2018, 07:01 PM   #5
jayoldschool
Moderator
Leaking wheel cylinder (if there is no puddle on the floor). Get the drums off...
jayoldschool is offline   Reply With Quote
Old 09-07-2018, 08:31 PM   #6
PGSigns
PGSigns's Avatar
Since you need to work on it I would do the brake split and go to the dual pot master cylinder. Just so much safer if something happens like you have going on now.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-10-2018, 05:25 PM   #7
jocko
jocko's Avatar
Does your mc have the rubber gasket under the cap? Confirm whether wheel cylinders are leaking by removing the drum, can’t always tell just by looking for a puddle. I wouldn’t just replace the mc until you know why it drained. If you do replace it, then I concur with above comment about a dual res mc upgrade is a worthwhile upgrade for safety. Several threads on here for how to do that.
Old 09-10-2018, 06:25 PM   #8
fightingcec246
Thanks to all. I found the "culprit". My left rear slave cylinder is the leaking cyclinder. I decided that I will replace the master cylinder and all four cylinders. I want to do the upgrade to dual master, but needed an expedient route to get my truck back on the road - its my daily driver. I looked up the conversion to dual master cylinders, looks pretty straight forward. Regards - joe
Old 09-10-2018, 06:26 PM   #9
fightingcec246
It does have the rubber cap under the metal cap. What does that thing do anyways?
Old 09-10-2018, 07:01 PM   #10
jayoldschool
Moderator
Seals against air/moisture.
OP: glad you found the issue. I went through the same thing. Get the 67 truck master. Replumb the lines. FRONT port on the master to the front brakes, one line down to the splitter that you can reuse. REAR port to the rear line, use a connector, not a compression fitting!
Old 09-10-2018, 07:03 PM   #11
fightingcec246
Thumbs up...
brake, fluid, leak
