Old 09-07-2018, 02:02 PM   #1
pinturbo75
pinturbo75's Avatar
master power legend series disc brake kit
has anyone used this kit? I'm looking at it specifically because it used an 11 inch rotor and maintains the rest of the stock steering components. want to keep 15 inch wheels. thanks steve.
https://www.mpbrakes.com/front-brake...18FE09C070F266
1972 gmc 3500 ramp truck, 350, sm465, dana 70 rear
pinturbo75 is offline   Reply With Quote
Old 09-07-2018, 11:26 PM   #2
Captainfab
60-66 Nut
Re: master power legend series disc brake kit
If you are converting to 5 lug, you can buy everything except for the spindles from your local auto parts store. The 11" rotors are stock '73-'87 C10 parts.
Old 09-08-2018, 12:26 PM   #3
pinturbo75
pinturbo75's Avatar
wanting to stay 6 lug.
do you sell a kit? would rather support this board than a company.
looking to add power disc with a drop spindle, power steering and ac.
Old 09-08-2018, 05:03 PM   #4
Chevy Fleetside
Chevy Fleetside's Avatar
You can order 6 lug rotors from Summit for under $130. If you want a parts list I am sure we can put one together. ECE has spindles for about $279 a pair. https://www.earlyclassic.com/catalog...&keys=&=Search These spindles will bolt up to your ball joints and tie rod ends. The rest is putting the parts together.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 09-09-2018, 12:33 AM   #5
Captainfab
60-66 Nut
No I do not sell complete disc brake conversion kits. There are already many, many, many suppliers that do. The only things that I make and sell that you might need are the power steering box adapter plate and the brake booster bracket. The parts that I make and sell are not just copies of what everyone else sells. Mine position the steering box correctly and the booster bracket mounts the booster securely to the pedal bracket using all factory holes and attachment points.
