Closed Thread
Old 09-08-2018, 08:25 PM   #7226
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by 84yotamann View Post
Well for my first post ever I thought I’d share, long story short I traded a buddy work for doing a cab swap for a 67 LWB 2wd 4spd. It has a 6lug on front end which I would assume is factory and a full float Dana 60 8lug in the rear with leafs. I left work a little to happy on a Friday and grenaded the rear end. So I got a full rolling 74 chassis with SBC th350 2wd lwb. My plan is to swap the 12bilt into the 67 along with all the front suspension components to make it 5lug all around. Also I will put the th350 in it once I pull it and rebuild it.
So i finally got around to pulling the rear end and pressure washed it. Pressure washed the th350 in the chassis and it will get pulled next. Started measuring leaf spring lenghts and found I can not swap leaf spring due to length and spring width 😟. And I need a new driveling because the 60 had a 1350 ujoint and 12 bolt is 1310 I believe.
And if anyone could help me identify which trans this is would be very helpful.
I can't identify the trans without a pic of the pan. But, it's definitely a long tail shaft!!!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Ol Blue K20 is offline
Old 09-08-2018, 09:55 PM   #7227
racenhogs
Just did some bearing work and hoping someone sees that I'm in need of a HO52 rear carrier with a 4.10 gear set...
racenhogs is offline
Old 09-09-2018, 02:42 AM   #7228
84yotamann
3757chevy, the second half of the driveline is short do too the yoke to axle centerline being longer than the 12bolt,but yes I have herd of those.
Ol bluek20, the trans is a 4spd manual doesn't have a pan. I thought it might be an sm420 or sm465 but doesn't look like any identifing features match with one of those
2008 GMC 2500HD 6.6l Duramax Diesel
67 GMC long bed 2wd my "main squeeze"
85 Toyota project, SBC, TH350, D60 front, D70 Rear, 3 linked Front, 4 link Rear.
43 Willys, family heirloom
84yotamann is offline
Old 09-09-2018, 12:20 PM   #7229
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
There is one here on Craigslist https://slo.craigslist.org/pts/d/eat...678463992.html
68SWB4x4 is offline
Old 09-09-2018, 05:48 PM   #7230
3757chevy
3757chevy's Avatar
...I see...
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline
Old 09-09-2018, 07:11 PM   #7231
orangek5
orangek5's Avatar
Put on new finned diff cover
1970 Jimmy 4x4 IL6
1971 Jimmy 4x4 350ci v8
1971 SWB 327ci v8
1972 Short Stepside 305ci v8
1972 Blazer 2WD CST LS9 350ci 4sp
1999 4 Door LB 1 Ton Old Body Style 5.7 v8
orangek5 is offline
Old 09-09-2018, 07:24 PM   #7232
Metaldoc
Metaldoc's Avatar
Now the trucks running I could catch up on needed repairs on the Woodshed. Burning all the repair scrap wood. I did have it out to local show on Fri. and to do a full detailing on it. All the glass and the dash.
Do it, Do it right, Do it right the first time
Metaldoc is offline
Old 09-09-2018, 08:24 PM   #7233
oneperfectrun
oneperfectrun's Avatar
Added digital gauges to my truck a couple weeks ago.
Jeff
oneperfectrun is offline
Old 09-09-2018, 08:29 PM   #7234
oneperfectrun
Finally got time to recover my seat and get it back in the truck this weekend. It sure is a lot more comfortable to drive with the seat recovered.
Jeff
Old 09-09-2018, 08:36 PM   #7235
ZEKE68
ZEKE68's Avatar
Trouble shooting the fact that I have zero rear braking with a new master cylinder and proportioning valve. Have a hard petal even with the left rear bleeder cracked open, and no flow. Think I must have a bad proportioning valve. Got another one ordered, and that doesn't fix it I will look at the rear rubber hose next. The valve trip rod is in the middle and the light is not on, and I have verified that the brake light works. Going to charge the ac tomorrow while I wait on brake parts.
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline
Old 09-09-2018, 08:43 PM   #7236
ZEKE68
ZEKE68's Avatar
ZEKE68 is offline
Old 09-09-2018, 08:46 PM   #7237
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Sounds like the prop valve pin needs to be reset
68SWB4x4 is offline
Old 09-09-2018, 09:29 PM   #7238
Zeroman
Zeroman's Avatar
Leroy got some new wheels and tires.....
Zeroman is offline
Old 09-09-2018, 09:39 PM   #7239
Ol Blue K20
Leroy was my grandpa's name. I love it........
Dale
Old 09-09-2018, 09:49 PM   #7240
nlped
nlped's Avatar
Got some work done to the chassis going under Walter...
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline
Old 09-11-2018, 09:00 AM   #7241
ZEKE68
ZEKE68's Avatar
Was a bad proportioning valve. Changed it out.
ZEKE68 is offline
Old 09-11-2018, 12:28 PM   #7242
71gmcC15
71gmcC15's Avatar
Painted my front hubs today. I know I need new rotors but this will at least makes it look good till I can get some
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline
Old 09-11-2018, 04:20 PM   #7243
In The Ten Ring
I am with you there! I recently painted my daily driver's drums and those look so much better. *I very nearly painted the hubs also but figured I needed high temp paint. I did paint the center of the rotors, just to allow the alloy wheels to not have "dissimilar metal corrosion" as much.
In The Ten Ring is offline
Old 09-11-2018, 04:33 PM   #7244
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Painted my engine today.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline
Old 09-12-2018, 01:16 AM   #7245
dflarsen77
Active Member
Haven't posted progress in awhile because I've just been slowly taking it apart. But I'm planning to finally get the frame fixed and the body media blasted tomorrow, so I got the bed onto a dolly this past weekend, and tonight I got the doors disassembled and taken off, and the windshield and rear window off. I tried to do Lockdoc's old method where you stuff the garden hose under to kind of hold the seal out, but my seal is rock hard so it wasn't happening. Had to cut it. But I got it all out! Now it's ready for blasting and then I'll be painting for a week or so!
David Larsen
1970 Chevrolet C-10
dflarsen77 is offline
Old 09-12-2018, 10:28 AM   #7246
tdangle
tdangle's Avatar
I can see the gauges now. Upgraded to led lights
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline
Old 09-12-2018, 01:05 PM   #7247
3757chevy
3757chevy's Avatar
WOW looks good.
MIKE
Old 09-12-2018, 02:03 PM   #7248
stevenfromtexas
stevenfromtexas's Avatar
been driving my pickup around as much as possible. turned over 500 miles today so-far-so-good nothing has come flying through the hood yet....that's a good thing. peeled-out at a stop light today too....hahahahah i can only imagine my little 250 saying, "WTF was that for???"
Steven
'67 SWB, 250ci, 3OTT.......this is my first build......
I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71"
stevenfromtexas is offline
Old 09-12-2018, 02:06 PM   #7249
stevenfromtexas
looks very nice!!
Steven
Old 09-12-2018, 04:04 PM   #7250
3757chevy
3757chevy's Avatar
Originally Posted by stevenfromtexas View Post
...peeled-out at a stop light today too....hahahahah i can only imagine my little 250 saying, "WTF was that for???"
....CAUSE IT COULD
MIKE
Closed Thread
