09-01-2018, 06:51 PM | #1 |
Narrowed rear end info...
Ok I’m swapping to an 8.8 rear from a 98 explorer and running moser axles with 31 splines. I’m taking 2-15/16” off the long tube and running equal length axles and will center the pumpkin. My question is how wide of a wheel are y’all getting with factory trailing arms and frames? I’m thinking about a 11-12” wheel but unsure if they will fit with trailin arms. Only going with a 17” wheel as of now.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
09-02-2018, 12:56 AM | #2 |
60-66 Nut
Re: Narrowed rear end info...
I do know that a 12" wheel will fit, but I believe you can go up to a 14" wide wheel. Of course the tire width needs to be considered as well.
09-02-2018, 09:32 AM | #3 |
It's Better With Nitro
Here is an old pic of my rear with 16x12 wheels and 31x16.5 tires. A 14" wide wheel would not be a problem with attention to backspacing.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
09-02-2018, 01:01 PM | #4 |
Oh I really like the idea of that..... I need to find some wheels I guess that I can mock up to because the ones I will be running will have to be made to fit.
09-02-2018, 08:43 PM | #5 |
09-03-2018, 11:12 AM | #6 |
meowMEOWmeowMEOW
I fit a 15x12 on a stock width 12 bolt without an issue. I did decide to go down to an 11" wide wheel on my next set of wheels after changing my setup around.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
09-03-2018, 11:30 AM | #7 |
I set up the housing to be 51" wide from housing end to housing end.
09-03-2018, 04:30 PM | #8 |
09-09-2018, 08:33 PM | #9 |
Ok so after doing some figuring the 8.8 will be around 56” flange to flange as opposed 60-61 on my stock 12 bolt. So I know 5.5” backspacing on a 15x10 will fit a 295/50/15 but will rub a touch. So I think we’re going to put 9” big bearing ends on my 8.8 and probably bolt in axles of equal length. Wish I could get my truck in the garage and get the old rearend pulled out and on the ground to start fitting the new. I think I’m going to do a 8.8 build later once the pictures are taken and done. I need to find some wheels to work with maybe just have a set of steel rally’s built for now!
09-10-2018, 12:01 AM | #10 |
60-66 Nut
The correct way to go about this is to purchase your wheels and tires first. Then with them at your desired outside width to fit inside the bedsides, measure the WMS to WMS width of the wheels. Then build your differential to that dimension.
