Old 05-13-2004, 11:35 AM   #1
smokekiki
Mike
smokekiki's Avatar
headlight relays
l can't find the post about wiring in relays to make the headlights work better.Can anybody help me out?
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 05-13-2004, 12:04 PM   #2
67chevemall
67chevemall's Avatar
http://www.madelectrical.com/electri...adlights.shtml
This MAD site is great!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 05-13-2004, 12:34 PM   #3
my new 72
faster, faster, faster
my new 72's Avatar
The only problem with that site is that they want you to buy their relays and kits with their instructions. They do not really tell you how to do it. There are a few on the board that have done this upgrade that will be more than happy to share the knowledge these guys want you to pay for.
I'm going to Law School, wanna debate? It's good practice.
my new 72 is offline   Reply With Quote
Old 05-13-2004, 12:44 PM   #4
smokekiki
Mike
smokekiki's Avatar
my new 72,thats what I am looking for.I couldn't find it doing a search.I think the price madelectric wants is pretty high considering relays are $5-10 a piece.
Old 05-13-2004, 12:55 PM   #5
UP GRADE
one set closer
UP GRADE's Avatar
hey you are look for djracer he has all the details and the relays.
UP GRADE is offline   Reply With Quote
Old 05-13-2004, 12:59 PM   #6
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Here is a wirind diagram that I have...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 05-13-2004, 01:03 PM   #7
72 CustomCamper
huh ???
Hmmmm.. I'll try it again...
Keeps saying file's too big. I don't see how because I got it off the board...
Chuck
Old 05-13-2004, 01:12 PM   #8
67chevemall
I just use their awsome work and go to Radio Shack for parts!
Old 05-13-2004, 01:18 PM   #9
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Here it is.
I did this mod and it sure makes a difference.
Can't blame MAD for not showing the actual diagrams.Afterall he is in business selling that kind of info.Not as if you can't get it off the web anyways
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 05-13-2004, 01:24 PM   #10
67chevemall
Good Work! Thats a great pic!
O/T But Hey!
Where would you run the electric fan relay from the Batt. Also?
Old 05-13-2004, 01:32 PM   #11
BobbyK
BobbyK's Avatar
Here's how my relays look all hooked up.
Looks a little confuseing but it goes like this.
Left to right:
1st relay
-brown wire=orig. low beam feed.
-Thick red is new 12 gauge wire going to low side of headlight.
-black=ground
blue (in rear of relay)=power feed from distribution block(blue wire is a 16g fusable link)
2nd relay
-all connections are the same as the 1st relay except the large green wire which feeds the high beam side of the light.
-the small green wires are the orig. high beam feed wires.
3rd relay
That's a relay with a built in Blade type fuse for a set of 55wt Hella driving lights.
and lastly is a 2nd power distribution block that is fed from a primary power distribution block I have mounted on the firewall.
Old 05-13-2004, 01:35 PM   #12
BobbyK
BobbyK's Avatar
I mounted mine to the fan shroud itself.
Old 05-13-2004, 01:40 PM   #13
67chevemall
Sweet Fans what are they?
Where did you get em?
Cheers
Old 05-13-2004, 01:40 PM   #14
smokekiki
Mike
smokekiki's Avatar
Talking
Thanks alot!Thats what I was looking for.Mike
Old 05-13-2004, 01:45 PM   #15
BobbyK
BobbyK's Avatar
They are PermaCool 14" electric fans.Got them from Summit for about $80 each.
Made the aluminium shroud myself.
Old 05-13-2004, 01:48 PM   #16
67chevemall
Very nice! I wish I was all done!
Old 05-13-2004, 02:46 PM   #17
neonlarry
neonlarry's Avatar
Here is another old board post
about headlight relays. Also link to low prices on relays.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
