Old 09-11-2018, 04:03 PM   #1
Mattchu60
5.3 Swap Oil Pan - CTS-V or Holley?
I have been reading a lot about the different oil pans to use - I'm putting a 5.3 into my lowered 87' C10 soon. I was considering doing the F-Body pan - but I started reading that the sump area was so long it could cause issues with the engine mounting position as it may hit the crossmember if not back far enough.
It looks like better options may be the CTS-V pan or the Holley pan. CTS-V is cheaper for just a pan, but when you throw in the dipstick, windage tray, pickup and pan - its coming close to the price of the Holley pan.
Is there a reason to get one over the other? My gut says go with the CTS pan as its a GM pan on a GM motor and it'll bolt right up without any issue.
Thoughts? Am I over-thinking this? Should I still consider the F-Body pan?
Mattchu60 is offline   Reply With Quote
Old 09-11-2018, 04:57 PM   #2
1957 Chief
Re: 5.3 Swap Oil Pan - CTS-V or Holley?
CTS-V pan. I was where you are at now, and I went with the CTS-V. Zero regrets.
Bubba
1957 Chief is offline   Reply With Quote
Old 09-11-2018, 07:48 PM   #3
Mattchu60
Thanks for the reply! Did you find you had to buy everything - dipstick, windage tray, etc?
Old 09-11-2018, 08:59 PM   #4
mongocanfly
mongocanfly's Avatar
You might even look at a c6 pan...http://www.improvedracing.com/tech/L...dimensions.php
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 09-11-2018, 09:32 PM   #5
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Don’t need the wind age tray. I just installed my CTSV pan yesterday.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 09-11-2018, 09:34 PM   #6
dayj1
Either one will work fine. I'd probably go with the CTSV pan simply due to cost.
When you compare costs, don't forget that the Holley pan doesn't come with a dipstick or gasket. The CTSV pan can be picked up with dipstick, pickup, and windage tray in the $150 range if you watch eBay for a while.
dayj1 is offline   Reply With Quote
Old 09-12-2018, 09:19 AM   #7
1957 Chief
All I needed was the pan, and dipstick/tube. Windage tray was the same.
Bubba
Old 09-12-2018, 05:55 PM   #8
Mattchu60
Thanks all for the responses - I ended up ordering a new CTS-V pan today.
Old 09-14-2018, 09:46 AM   #9
DaHos
DaHos's Avatar
Anyone have the part# for the dipstick/tube assembly for the CTS-V pan?
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 09-14-2018, 10:16 AM   #10
1971Stepside
Almost Satisfied
Tube Part No. 12584738
Dipstick Part No. 12584737
Pan Part No. 12631828 (comes with gasket and bolts)
Windage Tray Part No. 12611129 (don't have to buy this)
Pickup Tube Part No. 12621299 (comes with o-ring)
Old 09-15-2018, 07:31 PM   #11
Daaaanz67
I run the CTSV pan and the pick up tube, but still use the truck windage tray and truck dipstick/tube assembly. I just make a mental note where the oil level is full based on the pan capacity. You could also scribe a line on the dipstick for your reference. Just saving a few bucks.
Daaaanz67 is offline   Reply With Quote
Old 09-17-2018, 08:10 PM   #12
Tork?
For reference...
HOLLEY MUSCLE CAR PAN
FBODY PAN
CTSV PAN
GM PERFORMANCE/H3 PAN
Tork? is offline   Reply With Quote
Old 09-17-2018, 10:40 PM   #13
Mr_Rich
Mr_Rich's Avatar
I think the real trick is to get the right combo of parts for the engine you're using. I installed an LS6 in place of the LS1 in my '98 Firebird. The LS6 crate engine I bought was the CTS/V version and I had a lot of parts I couldn't use on my Firebird like the water pump, oil pan, and dual diaphragm clutch. Parts like the oil dipstick tube go into the block but aren't compatible with the exhaust manifolds and AIR tubes like my '98.
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E (sold)
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
Old 10-05-2018, 06:43 PM   #14
UniqueOdyssey68
UniqueOdyssey68's Avatar
CTS-V pan is a good option if you get all the pieces you need.
I just did a pan swap, learned it depends on many factors already mentioned, plus how much front drop you have, ground clearance w/front cross member, and if you're looking for a simple swap or are ok gathering up all the pan pieces.
I have a mild 3.5-4 inch drop, 60 series tires, but still didn't feel comfortable with the pan hanging below the x-member at all. Took a lot of measurements, and research on here. Went with the GMPP "H3/hot rod/muscle car" pan kit. $200 shipped fast to door from Summit (plus I got them to throw in some swag . Comes with everything needed, simple easy swap. Hangs down even with cross-member, plenty of ground clearance, clears top of cross-member with room to slide fingers underneath.
Keep in mind any bolt holes on pan that may or may not line up with your tranny bellhousing bolt holes. 1 didn't on mine, but I'm ok with that, others bolted up fine.
See pic -
http://67-72chevytrucks.com/vboard/a...1&d=1538174949
Hope that CTS pan works well!
- long term project '68 C10 true shortbed! Resto-mod. LS swap. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=769919 "I've still kept this project truck when anyone else would've given up and sold it as is. Giving up is easy, staying the course is part of life's journey"
___________________________________________
'68 C10 true shortbed, LS swap restomod. '03 Z71 daily, '63 AMC Rambler V8 survivor
UniqueOdyssey68 is offline   Reply With Quote
