Old 09-14-2018, 11:51 AM   #1
Driver_WT
Driver_WT's Avatar
Fan Temperature Switch
Can anyone recommend a fan temperature for a SBC 350 (screws into the intake manifold). What brand do you prefer and what on and off temp should i get?
Thanks.
Wade
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes
Driver_WT is offline   Reply With Quote
Old 09-14-2018, 12:11 PM   #2
NeoJuice
Re: Fan Temperature Switch
I just recently installed the Painless 30103.
https://www.painlessperformance.com/wc/30103
It's 185 on and 175 off. But I'm not sure how it's going to work out b/c I believe my stock thermostat in my 350 is a 195. So I might end up changing that out for maybe a 180?. I haven't started my truck yet so I'll see how it will perform. Also I don't have a heater in the truck yet either.
I also have a painless wiring harness in my truck.
NeoJuice is offline   Reply With Quote
Old 09-14-2018, 06:37 PM   #3
Volfandt
I went with a Temp switch/fan relay kit from Amazon, 200 on / 185 off and it works pretty good.
The sender comes with an adapter which screwed right into the Edelbrock Performer manifold temp port.
It's fairly accurate according to the mechanical temp gauge I run.
I run a 160 thermostat in the 350 and the setup keeps the temps at around 190 when cruising at 60 and below and 205 at extended idling and over 60. The fan hardly comes on unless I'm in bumper to bumper or interstate running.
Since the kit was pretty inexpensive, around $20 IIRC, I also installed a toggle switch to run the fan incase the sender fails.
For a few more $$$'s you can get an adjustable temp kit.
Dave
Volfandt is offline   Reply With Quote
Old 09-15-2018, 02:57 AM   #4
MiraclePieCo
MiraclePieCo's Avatar
I have an unused one I'll let you have cheap - it's 175 on/165 off.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 09-15-2018, 06:24 AM   #5
Driver_WT
Driver_WT's Avatar
Thanks for the offer, but I think I will go with 200 on/185 off.
