Old 09-04-2018, 05:22 PM   #26
Macdaddy1
Re: Problem with drive belt. Need Help!
I went to advanced auto and got the small belt went home and it was to small so went back and got the larger belt and it felt perfect.
Macdaddy1 is offline   Reply With Quote
Old 09-04-2018, 10:56 PM   #27
ls1nova71
ls1nova71's Avatar
Originally Posted by Jstock85 View Post
What alternator goes with that one?
It's the smaller one. He posted a pic of it in post #8, notice how much smaller it is than yours.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 09-05-2018, 09:52 AM   #28
Jstock85
Thanks. I may end up having to do that!
Jstock85 is offline   Reply With Quote
Old 09-05-2018, 09:55 AM   #29
Jstock85
Ok I see what your saying. Do you know if changing alternators would be a direct fit? Meaning same plug for the wiring harness? Same dimensions to fit in the bracket?
Old 09-05-2018, 09:56 AM   #30
Jstock85
Originally Posted by mongocanfly View Post
His looks like mine dude...
You mind sharing some info on your alternator? Brand, PN that sort of thing.
Old 09-05-2018, 10:28 PM   #31
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Forcing the belt on like you did means it's the wrong belt period. You are guaranteed to prematirealy wear out some bearings. Just take that belt off and go to the parts store and ask for 3 belts, each 1/2 longer... return the ones you don't use... simple.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 09-06-2018, 10:36 AM   #32
mongocanfly
mongocanfly's Avatar
Jstock...mine is a 105amp....
The numbers on it are...15755616W. 105A 111623 12V N
But I wouldn't change anything but the belt...if that's the jssue
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 09-06-2018, 10:45 AM   #33
Jstock85
Will do. Thanks again for your help!!
Old 09-15-2018, 11:17 AM   #34
Steve Cole
Did you get this issue resolved?
Steve Cole is offline   Reply With Quote
Old 09-17-2018, 08:23 AM   #35
Jstock85
Yes and no. I got the belt on by unbolting the alternator and tapping it down some and bolting it back down. Was then able to take the belt off but again could not get it back on. I still do not know the cause of this issue because I reused all the original parts from the teardown. Another member recommended buy several drive belts of different lengths, finding the one I need, and returning the rest. That is probably what I will end up doing.
Old 09-19-2018, 11:02 PM   #36
Steve Cole
Thanks for the reply, I wanted to check because I am having the same problem as you. Original components, original belt. The only difference was a replacement water pump but the "pulley", (for lack of a better word), was the same size. Suddenly. The belt no longer fits. This can't be coincidence.
Old 09-20-2018, 10:51 AM   #37
Jstock85
I have no explanation! I took the parts off clean and painted and put them back on had problems. I put new gaskets and seals on the water pump and power steering pump. Im gonna go the route of trying a couple different belts until I get the right one instead of swapping alternators. Good luck with yours!
Old 09-21-2018, 09:25 PM   #38
68c10airstream
68c10airstream's Avatar
Been there done that. When i changed from the 105 amp alternator with an oem stock belt to the optional 140 amp larger diameter alternator i used i believe a 1" longer belt to make it right. I went to the parts store with the old stock one, measured, looked up the application and got the longer optional one and no issue, it is perfect. This is on a 2003 5.3
68c10airstream is offline   Reply With Quote
Old 09-22-2018, 08:43 AM   #39
truckdude239
truckdude239's Avatar
im being serious you have the wrong idler pulley on there , i work on these things every day i bet if you got this pully im linking from advance you woul not have a problem getting the belt on
https://shop.advanceautoparts.com/p/...67a/10150983-P
David fuller
Ase Certified Mechanic
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
Old 09-22-2018, 08:47 AM   #40
truckdude239
Look at the pulley gaurds first pic is yours there is a big gap between the gaurd and pulley second pic shows the proper pulley with no gap
David fuller
2012 Subura outback
1999 honda accord
Old 09-24-2018, 02:46 PM   #41
Jstock85
ill take a look into that also. Thanks Dude
Old 09-26-2018, 01:05 PM   #42
4x4k30
4x4k30's Avatar
does this pulley that's in the yellow pic spin or is it not spinning ? also in the yellow pic this pulley should have a spacer behind it . and also check the tension pulley sometimes it will over center and cause the spring tensioner to bind up and only will go so far. and if all that's ok .loosen up the 3bolts where the spring tensioner goes to the block it will give you a little more room to mount the belt .
4x4k30 if trouble was money i would have plenty
4x4k30 is offline   Reply With Quote
Old 09-27-2018, 01:47 PM   #43
Jstock85
ill double check the tension pulley but the idle pulley is working as it should
