Old 02-16-2014, 11:50 PM   #1
Itnkrman
Rear End ID...no really!
Here's a few pics of my rear end...uh, trucks rear end...and I'd like a few expert's advise on manufacture, type and where to locate the ID numbers to help identify/confirm same. I believe it to be an Eaton rear-end based on what I've seen but I'd like some confirmation, additional info, etc...
Itnkrman is offline   Reply With Quote
Old 02-17-2014, 02:15 AM   #2
Captainfab
60-66 Nut
Re: Rear End ID...no really!
That is an Eaton HO32 under a '60-'62. It will most likely have 3.90 gears unless you are one of the lucky few to have the 3.38 gears.
Old 02-17-2014, 11:11 PM   #3
Itnkrman
So is there any way to definitively tell which gear ratio it is without cracking it open?
Old 02-17-2014, 11:28 PM   #4
72freak
Rottenwood Garage Member
72freak's Avatar
raise it, spin the wheels and count the rotation of the drive shaft. Then look it up on the net. It should get you close.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 02-18-2014, 12:40 AM   #5
BLK65K10
The 1/2 ton is stamped on the right front carrier flange. It will be two letters followed by 4 numbers. The letters designate the ratio and the numbers are the day and month made. If yours is original it should MA,MB,MC,MD,ME,MF,MG. which are all 3.90.
BLK65K10 is offline   Reply With Quote
Old 02-18-2014, 02:18 AM   #6
Brad54
Brad54's Avatar
Buy a new gasket for the rear cover, remove the cover, change the fluid, count the teeth on the ring gear and the pinion gear, do the math, reseal the rear cover and top it off with fresh fluid. Chances are that fluid is long overdue for a change.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 02-18-2014, 12:09 PM   #7
TJ's Chevy
TJ's Chevy's Avatar
Not to hog up the thread, Hey guys...I have the GM 12 bolt under my 66..Is that 4.11 or was a 3.73 ratio optional???
Old 02-18-2014, 12:51 PM   #8
rideblue00
rideblue00's Avatar
3.73 was usually the norm, most spids specified the 4.11, on 66's that is
rideblue00 is offline   Reply With Quote
Old 02-18-2014, 11:51 PM   #9
Itnkrman
Thanks all for the advise...I'll get it cleaned up this weekend and see what the numbers are and go from there.
Old 02-19-2014, 01:24 AM   #10
Captainfab
60-66 Nut
This is what I always suggest also when a guy wants to know what gears are in his rear end.
-Brad
Old 09-16-2018, 10:07 AM   #11
GMCNUT
GMCNUT's Avatar
Hey Lyle! I am so glad you wrote this - I’ve been needing to know how to tell if one has the rarer 3:38 gears vs standard 3:90’s. Can you tell me what the letters have to be for a 3:38? Or better yet, do you have a rear ended with 3:38’s in it?
GMCNUT is offline   Reply With Quote
