cowl/kick panel vent rust - need some ideas
After a 12 month hiatus, I am back working on my rusty cab. All rockers(inner/outer), cab supports, and some of the floor has been replaced. Cab corners as well.
Now I am into the more difficult stuff. I've patched a couple of places on my "inner cowl" around the heater motor. I cut a hole in the bottom of the passenger side just to check. Massive mouse next and once that was vacuumed out I found my old friend rust. I really don't want to replace the whole cowl panel due to the labor involved and looking at the patch panel I don't think it will solve my current issue. I've post a picture and the rust is on the inner inner cowl panel where the vent door mounts. I can't find any patch panels for this.... thoughts/ideas/prayers? |
Re: cowl/kick panel vent rust - need some ideas
They don't make patches for that area. I know Metaldoc made his own patch. You could search for his build and see if there are any detailed pics for it or ask him for pointers.
Or you could try and find a donor cab that has this area rust free - might be pretty tough... Or what I'm doing is cutting the whole cowl vent out and filling it in. Basically removing the whole vent. I'm doing this since I don't want rust forming there again and I'm adding a/c so I probably wouldn't use them as much. |
If you don't care about fixing it to look how the factory did it since it will be covered up anyway, you could maybe fab in some right angle iron where the "pegs" go for the actual vent flap. That would be pretty easy and you could cut out a lot of the rust and not have to worry about making a new piece.
Maybe Metaldoc will make you some! Lol |
![]() Join Date: Feb 2016
Do a search in the search box above and click the 67-72 button. You will find lots to threads on how to tackle this problem. Here is just one.
http://67-72chevytrucks.com/vboard/s...d.php?t=648369
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
I did some searching and saw what Metaldoc did - that is beyond my fabb'ing ability for sure.
However I cut some more of the cowl away and it is not as bad as I thought. I only need to replace about 3-4 inches on the bottom of where the vent door mounts. There is good metal to weld to on the rest of the oval. I also cut out the drivers side to see how it was, and no rust!! This is the first time I went looking for rust on this truck and didn't find any ![]() |
Cheers to you and your unsuccessful hunt!
![]() Join Date: Feb 2011
Here's what I did:
