Old 09-22-2018, 10:59 AM   #13
1774btcrew
1774btcrew's Avatar
Re: installing trim on bed, tailgate, and fender
Don't drill holes in your trim. I just got back from the c10s in the park show and saw beautifully restored trucks with new trim installed that had holes drilled to mount trim. Basically the ends of the trim are hard mounted with either screws or speednuts and studs. The center pieces are double sided tape. I feel if you use 3M tape and the paint is fully cured with all of the solvents out of it, you should be good for a whole lot of years
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
