Old 09-09-2018, 02:23 PM   #1
NC_John
NC_John's Avatar
No Start/Run Condition Problem......
Background - LSX swap, 04 blue/green PCM. DBW. Speartech standalone harness. Boyd tank with aeromotive pump. Build has got about 60 miles on it, still working through some new-build bugs but engine has been great so far.
Leaving the house the other day the truck started fine and ran fine but then just instantly died in the driveway like it was keyed off. I figured fuel was too low as it just cranked but would not restart. Pushed it back in the garage. Next day added a few more gallons of fuel to the tank but it would only turn over, no start.
Started digging into it yesterday. Noticed I could not hear the fuel pump cycle on to prime with initial key-on (in-tank pump is controlled by PCM through speartech harness). Got my voltmeter on the power terminals at the tank and had zero volts with key-on. Thought that explained the no-start. Jumpered the fuel pump relay terminals to manually run the fuel pump but still crank only, no start. Ran out of time to play with it for the day.
Today checked that the PCM has voltage, it does. Checked all the fuses (power to pcm, fuel pump, 02 heaters and injectors/ignition). They were good. Manually forced the fuel pump on again and cranked. No start. Checked ignition for spark (old school method- screwdriver in plug wire watching for spark to block). None. Pulled a plug and checked for fuel - none, dry as a bone. So it looked like the pcm was neither calling for the injectors to cycle or the coils to fire.
Went back and checked the signal for fuel pump relay to see if the pcm was even calling for the fuel pump. It was, it read 12 v with key on. Put the relay back in- no fuel pump. Bench tested the relay- was clicking and metered good with my ohmmeter. Jumped the power to the fuel pump again. This time it cranked some and then and fired up. A little more backfiring and popping through the exhaust than I would consider to be normal (its pretty free-flowing exhaust, barely muffled on a built engine). The exhaust smoothed out to a more normal idle within 15-20 seconds. Shut it off. It restarted normally. Pulled the relay jumper wire and put the relay back in. Nothing. Crank but no fire.
Even though it tested OK, I suspect the fuel pump relay is bad (some chinese one that came with the speartech harness) and ordered a replacement (its got a goofy ISO280 base so I don't have one here I can use to test). I'll have a couple relays here early next week.
Here is my confusion. If the fuel pump relay is indeed bad, why was I not seeing spark from the ignition or fuel on the plugs when I was forcing the fuel pump on with the jumper wire? There was no evidence that the engine was even trying to run. I was starting to think VATS had somehow been re-enabled. Do I maybe still have a problem with the PCM (cold solder joint going intermittent or something similar)? I don't think it would take that much cranking to prime the fuel line. I don't have a fuel pressure gauge but did order one from Summit that I'll have this week as well (couldn't do a loaner tool gauge on my fast fuel rails.)
I'm going to be nervous about driving this thing until I know why it tested the way it did. Again, if it is the fuel pump relay, which I will confirm when the new one gets here, why was there no spark or (perceived) fuel injector activity? Is the engine looking for fuel pressure before it tries to start? I don't know anywhere where it would measure fuel pressure from.
anybody know what might have happened/might be happening?
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 09-10-2018, 01:19 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: No Start/Run Condition Problem......
Check the little grounds on the harness that feeds the injectors and the coil plugs. Might be worth hard-grounding the PCM case as well. The internal ground can be suspect sometimes and case grounding can help. The ground for the injector driver board can break loose off its solder joint, and sometimes (worst case) the injector driver is for some reason fried.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-10-2018, 02:01 PM   #3
NC_John
NC_John's Avatar
Grounds are all good. Already have a ground strap from the pcm case to the cab. Cab to frame. Frame to battery. Checked all the way along with an ohmmeter.
I’m nervous that the pcm might be on the way out but don’t want to buy one and pay another hp tuners license to use it if that isn’t in fact the culprit.
1970 C-10 LWB "Blu"
Old 09-11-2018, 08:37 AM   #4
verdell
verdell's Avatar
Subscribed. I'm having similar issues as well. Just finished my swap this past weekend. Drove it to the muffler shop yesterday, had exhaust done, drove back to our shop and it hasn't started since.
verdell is offline   Reply With Quote
Old 09-13-2018, 08:00 PM   #5
NC_John
NC_John's Avatar
New fuel pump relay didn't solve my problem so back to the drawing board. This truck is the gift that just keeps on giving. Might dig into it some this weekend as the hurricane is going to give me plenty of indoors time.
1970 C-10 LWB "Blu"
Old 09-14-2018, 02:22 PM   #6
Flubyu
FYI. The PCM will only feed the fuel pump voltage to prime the system at KEY ON. After that the PCM needs to see signal from engine that it is running to run the pump. I learned this the hard way during my swap. Also, if VATS were the issue the engine would start, runs a couple seconds and die. I know this isnt much help but I didnt want you to chase your tail like I did trying to figure out my fuel pump issue.
'71 C-10 SWB Shop Truck
Currently 350/350, soon to be LS'd.
Flubyu is offline   Reply With Quote
Old 09-14-2018, 06:29 PM   #7
NC_John
NC_John's Avatar
Yeah, I know. I don't even get that initial prime sequence with key-on.
I have secured a GM Tech 2 scanner for the weekend so I am going to start digging into the pcm and see if I can figure something out. With this tropical storm/hurricane making all sorts of noise and mess outside it'll be a good weekend to spend some time in the garage.
Thanks for the input.
1970 C-10 LWB "Blu"
Old 09-15-2018, 06:38 PM   #8
NC_John
NC_John's Avatar
Mixed results today but I suspect my pcm is on the way out.
Prior to hooking up the tech 2 I plugged in a fuel pump relay and the truck started normally and repeatedly. Hooked up the tech 2 and was able to start and stop the fuel pump at will. BUT, I kept having communication errors with the tech 2 and at times the idle would get very rough.
That worked until it didn't. Without changing anything, I've since lost proper operation, truck won't start, can't control the fuel pump through the tech 2. I pulled the seat out and have gone through all the wiring at the harness. Everything looks lovely and I can't find any problems.
I'm thinking I have a ground or power issue within the PCM and just going to get another one. I hate to buy one for nothing and have to get another HP Tuner license for it but can't really think of what else to do.
1970 C-10 LWB "Blu"
Old 09-15-2018, 11:51 PM   #9
ls1nova71
ls1nova71's Avatar
I assume this is a factory harness that speartech reworked? Have you contacted them?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 09-16-2018, 06:35 AM   #10
NC_John
NC_John's Avatar
Brand new harness. I have not yet.
1970 C-10 LWB "Blu"
Old 09-22-2018, 07:48 PM   #11
NC_John
NC_John's Avatar
Got the SOB figured out today. Turned out to be an intermittent connection with the fuel pump on signal from the pcm. The issue was inside the base of the fuel pump relay so whenever I probed it with my voltmeter, it would make contact and I could not see the fault. I found it just by luck when I was working my way through the harness and the wired jiggled the right way. I removed the bad base and relay and installed one I had in my toolbox, no more problem.
Glad I finally got this one resolved. I was at the point of calculating how much tannerite it was going to take to send this truck into orbit.
1970 C-10 LWB "Blu"
Old 09-22-2018, 11:29 PM   #12
mongocanfly
mongocanfly's Avatar
Yeehaw...glad you got it....tannerite is would probably also jiggle that wire loose...haha
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 09-22-2018, 11:41 PM   #13
oldman3
oldman3's Avatar
Good deal, the little things will get you everytime...Jim
oldman3 is offline   Reply With Quote
Old 09-23-2018, 06:00 AM   #14
NC_John
NC_John's Avatar
Thank you guys. Like a friend of mine said - "intermittent electrical problems are the work of Satan himself."
You have to expect some teething problems on a new build but this one was no fun. Something as simple as that being so hard to find. Yikes... Almost makes me want to sell the truck and buy a set of golf clubs.
1970 C-10 LWB "Blu"
Old 09-23-2018, 09:53 AM   #15
oldman3
oldman3's Avatar
Oh no, don't go to the dark side...Jim
Old 09-24-2018, 07:14 AM   #16
NC_John
NC_John's Avatar
Nah, I hate golf. That's just how bad this got. I'll tell you one thing- this sure has upped my knowledge of the PCM and wiring harness exponentially. I am confident I could wire up a standalone harness pretty easily now.
1970 C-10 LWB "Blu"
Old 09-24-2018, 08:23 AM   #17
jjzepplin
jjzepplin's Avatar
That is fabulous! I need a harness! Please spend extra time on the fuel pump relay connections prior to sending, Thanks! HAHA! This makes me a little iffy on whether I should do the swap now. Dangit. I already bought the donor.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-24-2018, 08:35 AM   #18
NC_John
NC_John's Avatar
Well....
I still wouldn't trim down or build a standalone from a donor harness, at least up to or of a certain age, as they get damaged and brittle over time. Insulation gets hard and damaged, copper starts to corrode and the plastic connectors get brittle and break. I work on enough of this crap at work on trucks with 100k+ miles that I see it daily. That was a big reason why I paid the money for a new one. Figured it would be one less thing to worry about (who knew?).
I don't know what it would cost to build a new harness from scratch with all new parts. I'm sure all the special connectors alone would add up significantly. Might not be economically worth it unless you were buying parts in bulk and semi-mass producing them.
As far as cost- mine went over the top because my "cam only drop-in 6.0" turned into a full blown 600 hp stroker. The only parts I ended up keeping off the complete donor engine I bought was the block (which I used) and the 317 heads (which I am not using but kept) in case I decide to add significant boost later. And then adding all that additional power meant I had to keep upgrading everything down the line so it would survive. It just snowballed on me. Its still going on. I am not done spending money on it yet.
1970 C-10 LWB "Blu"
Old 09-26-2018, 07:31 AM   #19
jjzepplin
jjzepplin's Avatar
Good to hear it was only a relay! Was it the relay that came with the harness? Are you happy with the harness?
Old 09-26-2018, 08:41 AM   #20
NC_John
NC_John's Avatar
It was actually a connection/termination within the relay base. It was part of the manufactured harness. Other than that, I have been very happy with it.
1970 C-10 LWB "Blu"
