Old 09-23-2018, 07:10 PM   #1
Edahall
A/C Part Identification
The air filter rubbed through this A/C line on my 1990 Suburban. What's the name of this part and where would I buy another one?
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 09-23-2018, 10:19 PM   #2
100%Chevy
Re: A/C Part Identification
High side line from the condenser to the evaporator,with the expansion tube.
Looks like you have front and rear air,so be sure to tell them when you order the part.
Mike.
100%Chevy is offline   Reply With Quote
Old 09-24-2018, 10:33 AM   #3
Edahall
It's a very difficult part to find so I'm going to try JB Welding it.
Old 09-24-2018, 10:41 AM   #4
100%Chevy
J.B. Weld won't work at all!
Try to find a used one or have your local a/c shop build you one.
Mike.
Old 09-24-2018, 10:51 AM   #5
Zachary17
Zachary17's Avatar
Rock auto has that part.its in with the ac hoses.
Zachary17 is offline   Reply With Quote
Old 09-24-2018, 09:54 PM   #6
andyh1956
Get a new Air Filter while you're on RockAuto!
andyh1956 is offline   Reply With Quote
Old 10-02-2018, 12:05 AM   #7
v30crewcab
v30crewcab's Avatar
find someone who welds aluminum and they can fix it for you. had to do that on my brothers ac hose before.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is online now   Reply With Quote
