Old 04-30-2017, 08:17 PM   #1
Ronald29609
200-4R shudder
I made a hard emergency stop that resulted in the engine/trans shuddering wildly like it was going to break off the mounts.
After driving 40 miles or so back home the shudder is greatly reduced but it is still there even in neutral.
Any ideas? Thanks in advance.
Ron
Ronald29609 is offline   Reply With Quote
Old 05-01-2017, 08:18 AM   #2
dennislbrooks
dennislbrooks's Avatar
Re: 200-4R shudder
Maybe something to do with the lockup????
https://www.thoughtco.com/diagnosing...roblems-262653
1942 Chevy 1/2-ton Rod, 1959 GMC 1/2 ton Fleet Step side, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T, 2018 Bolt
dennislbrooks is offline   Reply With Quote
Old 05-01-2017, 07:00 PM   #3
Tom
driving is in my blood
Tom's Avatar
Re: 200-4R shudder
Shudder in neutral? What makes you think its the trans then? Shudders only apply when the vehicle is moving IMO.
Old 05-02-2017, 06:07 AM   #4
cadillac_al
Re: 200-4R shudder
Is this what happens when you don't have a brake switch to unlock the converter?
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 05-02-2017, 07:24 AM   #5
YoungPup1977
Re: 200-4R shudder
the brake switch does not control the TCC, the brake switch disengages the TCC when you press on brake when the TCC is engaged (applied).....
YoungPup1977 is offline   Reply With Quote
Old 05-02-2017, 07:37 AM   #6
dennislbrooks
Re: 200-4R shudder
Be interesting to find out the problem. I run a relay off the brake switch thru a T- shifter switch to trans. Like having 5 gears. Hopefully ther is a cheap fix for Ronald. . Sounds like it could be a torque converter problem. Maybe some trans gurus will jump in.
Old 05-02-2017, 02:33 PM   #7
D13
D13's Avatar
Re: 200-4R shudder
Shuddering running in neutral, foot of the brake, on level ground?
You broke a mount, most likely.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 05-02-2017, 02:57 PM   #8
Tom
Tom's Avatar
Re: 200-4R shudder
Torque convertor clutch went bad after maybe 1000 miles on my old built 200-4r in a 79 c10 I had.
Old 05-02-2017, 10:31 PM   #9
YoungPup1977
Re: 200-4R shudder
Drive it down to Albany on 87 at around 75 MPH and see if it still shudders when you get to Albany....If it does not shudder any more....issue fixed.
Old 09-22-2018, 12:48 PM   #10
Ronald29609
Re: 200-4R shudder
Thanks for the replies. I think it was carb flooding because after driving awhile it went away. Got a new carb and no problems since.
Old 09-24-2018, 08:35 AM   #11
YoungPup1977
Re: 200-4R shudder
Glad you figured it out...
At any time during the "shudder" did you smell gasoline or notice smoke coming out of the tailpipe.....
when people hear the word shudder it appears they relate it to the TCC/trans....maybe it was running rough enough to feel like the engine was coming off the mounts.
200-4r, shudder, transmission
