Old 01-18-2012, 07:26 PM   #1
tucsonjwt
Ford 8 lug vs. Chevy 8 lug wheel
Will a stock wheel from a Ford F250 8 lug fit on my C20 8 lug truck? I picked up a spare tire and wheel from a Ford and am not sure if I can use it as is or if I have to remount it on my spare wheel.
tucsonjwt is offline   Reply With Quote
Old 01-18-2012, 07:41 PM   #2
76stepsidechevy
Re: Ford 8 lug vs. Chevy 8 lug wheel
Should bolt right up. As far as I know 8 lug is 8 lug for 3/4 and 1 ton anything.
76stepsidechevy is offline   Reply With Quote
Old 01-18-2012, 07:49 PM   #3
ka_jd7and1
is a fungineer
ka_jd7and1's Avatar
What year are the wheels?
The newer stuff (97+?) is metric and will not fit. The older stuff is 8 on 6.5" and will fit. The center hub hole might be a different size though.
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons
1978 Impala 2-door, race 350/T350 - the new race car, in progress
1968 Chevy C10 longbed- 3/5 drop, currently undergoing a heart transplant
ka_jd7and1 is offline   Reply With Quote
Old 01-18-2012, 07:51 PM   #4
Sicklajoie
The Niner
Sicklajoie's Avatar
Ford rims are lug centric. I have them on my 69 C/20.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 01-18-2012, 08:28 PM   #5
black_sheep454
Will fit as Long as it's of a truck older than 97
1968 chevy lwb, getting ready to join forces with the 70 gmc
1970 gmc swb, getting ready to be a 68 chevy swb
1971 gmc lwb 2500 2wd Sierra Grande
1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins
black_sheep454 is offline   Reply With Quote
Old 01-18-2012, 09:01 PM   #6
84chevy4x4
84chevy4x4's Avatar
as far as wheels go, atleast for 4x4s i know you have a 2wd truck. but 8 bolt dodge and ford will bolt to a chevy but an 8 bolt chevy wheel has a smaller center hole for the hubs and wont fit onto a ford or dodge im pretty sure
1984 Chevy K20 work in progress
1977 Chevy C30 Dump
1979 GMC 35 4x4 Dump
1969 GMC 1500 Rat
84chevy4x4 is offline   Reply With Quote
Old 01-19-2012, 12:36 AM   #7
thinair
thinair
thinair's Avatar
^^^^^correct.
thinair is offline   Reply With Quote
Old 01-19-2012, 05:01 AM   #8
tucsonjwt
Ford wheel is pre 1998, so I guess it should fit. thanks.
Old 01-19-2012, 05:26 AM   #9
Rogier
I have 2002 ford HD wheels and they fit on the 8 lug Chevy 81 in my case. It will not fit the Dana 60 axles of one of my friends from the same year.
Rogier is offline   Reply With Quote
Old 01-21-2012, 03:44 PM   #10
tucsonjwt
I just test fitted the Ford 8 lug on my 83 C20 and the lug bolt pattern was a match. There is about 1/4" slop in the center (hub) hole, so I can see how the Chevy rim would not fit a Ford because the Chevy center hole would be too small. The Ford rim should do the trick as a spare. Thanks.
Old 04-27-2016, 02:18 AM   #11
inkfamous13
Talking Re: Ford 8 lug vs. Chevy 8 lug wheel
I know thos is old thread. But anyone know the exact center hub hole size on 16inch 8 lug wheels off a 1966 c20? Trying to order or make a type of push thru bullet center cap. We were robbed begining of year all my tools stolen. So havnt got a caliper measuring tool yet. Been slowly getting back in order of importance till insurance check comes thru. Any help will be greatly appreciated. Thnx
inkfamous13 is offline   Reply With Quote
Old 04-28-2016, 04:33 PM   #12
oltronj
what he said
oltronj is offline   Reply With Quote
Old 02-17-2018, 09:00 PM   #13
dragonball98312
dragonball98312's Avatar
I know this is an old thread but does any know if the 1/4" slop will cause me any problems? I just got a 73 c20 that had 16.5s with bad tires and i replaced with 16x7 ford rims. Drives fine with them but wanted to check
dragonball98312 is offline   Reply With Quote
Old 02-18-2018, 10:52 AM   #14
KrazyRay
KrazyRay's Avatar
The Ford rims work good on the Chevy. No worries.
KrazyRay is offline   Reply With Quote
Old 02-18-2018, 11:37 AM   #15
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
The only difference...not slop, is that the wheel is held by the lug nuts (lugcentric) on Dodge and Ford, and not hubcentric that is held Snug by the hub and lug nuts. Thus the bigger hole which was also needed to clear Ford Dana 60 hubs as they have an extra lip on them that Chevy Dana 60's do not.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 02-18-2018, 01:14 PM   #16
tucsonjwt
I ended up getting the tire dismounted from the Ford rim and mounted to my Chevy 8 lug wheel, and selling the Ford wheel on CL. Since then, I was able to find some nice 8 lug Dodge chrome steel wheels which had good tires and I still have the Dodge wheels on the C20. I bought the set of 4 Dodge wheels with good Yokohama tires ($250) from CL and got another 2 Dodge wheels with BFG commercial T/As from the local pick and pull junkyard ($70). Since I drive less than 1000 miles annually (all city) these tires are all I need. So now I have 11 wheels and tires (including the original Ford spare tire.
I also picked up some used tires for my luxury sedan (2002 Cavalier) since I was getting a tire puncture every 2 months on that car. Whenever I get a flat it is always on a street with no place to pull over, so I have to drive a block or so to get to a side street, and by that time the sidewall on the tire is shot. The tires and wheels are $35 each at the local pick and pull.
Considering the cost of new tires, I think I am going to buy only used tires in the future. I would not trust them for long highway driving, but I usually rent a car if I am going out of town.
Old 02-18-2018, 03:37 PM   #17
dragonball98312
Alrighty thank you
Old 02-18-2018, 03:58 PM   #18
dragonball98312
Heres the space and what they look like with my caps
Old 03-09-2018, 06:02 PM   #19
Racmad2019
I am still looking for a decent set of 4 hub caps for my 73 GMC, 8 lug, 3/4 ton. I found two Chevy for the time being.
Racmad2019 is offline   Reply With Quote
Old 03-09-2018, 06:06 PM   #20
Racmad2019
[ATTACH]Name:  hub2.jpg
Size:  59.6 KB[/ATTACH]
Here are the ones i have; but looking for GMC
Old 09-24-2018, 07:58 PM   #21
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I just wanted to confirm...
97 and older 8-lugs from all makes will fit 73-87 chevy 8-lugs?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 09-24-2018, 10:00 PM   #22
andyh1956
I think I have one 16" GMC cap on my 4 door. I'll check tomorrow.
andyh1956 is offline   Reply With Quote
