Old 09-25-2018, 05:49 PM   #1
Epiparkour
350 Identification
Hey guys I’m new here and I was hoping one of you could help me identify my engine. I’ve seen that using a combination of the casting number, vin, and another number stamped into a flat part in front of the passenger side cylinder head will give information regarding the factory the engine came out of, the year, and the original car/truck it was in.
The only problem is I don’t know how to apply that and what my numbers mean exactly. I’ve seen that the vin is supposed to be number number letter then a string of 6 or so numbers but mine appears to be letter number letter then 6 numbers, so its got me a little bit stumped.
Sorry if this seems like a stupid question but this is my first 350 rebuild and I’d like to know a little bit more about my particular engine. The casting number is 3970010, its a 350 from what i believe to be late 60’s to early 70’s and I have included a picture of the codes in front of the cylinder head.
Any help is appreciated thank you guys.
Epiparkour is offline   Reply With Quote
Old 09-25-2018, 06:21 PM   #2
ka_jd7and1
is a fungineer
ka_jd7and1's Avatar
Re: 350 Identification
So the easiest thing to do is use the 3 letter code at the end of the sequence. In your case it is TYR.
There are plenty of sites online you can use to decode this suffix. By searching it online, you come up with 2 possibilities:
TYR 1975 350 van & bus L LS9 165 4 C-20 to 3500
TYR 1979 305 conv. cab, m/t U LG9 140 2 C-20 to 3500
Since you know your block casting number, you can rule out the 305 as an option, since block 3970010 would be a 350.
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons
1978 Impala 2-door, race 350/T350 - the new race car, in progress
1968 Chevy C10 longbed- 3/5 drop, currently undergoing a heart transplant
ka_jd7and1 is offline   Reply With Quote
Old 09-25-2018, 07:06 PM   #3
Epiparkour
Very cool thank you. Fitting that it potentially came out of a C-20 as its going back into a C-20.
Now in the V1119TYR, from what I’m seeing this means that it was made November 19th? And the V means it was made in Flint Michigan? Is this accurate or is this speculation?
Old 09-25-2018, 07:23 PM   #4
geezer#99
geezer#99's Avatar
Not only accurate, but bang on! LOL!!
Some links for you.
https://www.mortec.com/
http://www.nastyz28.com/decode.html
Old 09-25-2018, 07:34 PM   #5
Epiparkour
Thank you guys so much, I’ll make sure to use those links for future projects. This answers some fun questions, I appreciate you guys helping out the newbie
Old 09-25-2018, 07:36 PM   #6
YoungPup1977
The block should have a casting date on it as well, which tells you when the block was cast. Example "C 12 6" Which would be month / day / year
C would be the third month of the year (march) 12= day 6 = year of casting of a 010 block....there is a range of years for the 010 block.
So you know the block was assembled on nov 19 but what year ? this is where you look for the casting date on the block would assist you in the year... hope that makes sense.
The assembly date is normally within a couple months of the actual casting date on the block....not always but can be used as rule of thumb.....
YoungPup1977 is offline   Reply With Quote
Old 09-25-2018, 09:05 PM   #7
Epiparkour
I see a code similar to that on the transmission flange that says K 13 5 but its not stamped in its embossed out, so does that mean the block was cast on Nov 13 1975 then put together 6 days later on the 19th?
Old 09-25-2018, 09:27 PM   #8
geezer#99
geezer#99's Avatar
Are you sure you haven’t done all this before! LOL!!
Those numbers are close.
Normally a week after casting they were installed.
Old 09-25-2018, 09:43 PM   #9
Epiparkour
Well, first time on a chevy v8. I did a previous restoration on a 1930 f*** pickup, sorry for the sacrilige. Now my current project is a real truck a 66 chevy c20. So getting used to all the chevy info now.
Old 09-26-2018, 11:26 AM   #10
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by Epiparkour View Post
Well, first time on a chevy v8. I did a previous restoration on a 1930 f*** pickup, sorry for the sacrilige...
No need to apologize for restoring any old truck or car. There's some old fords I wouldn't mind having -especially a 30's pickup.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 09-26-2018, 11:33 AM   #11
geezer#99
geezer#99's Avatar
How'd you Like this pair in your grudge!
My buddy down the road a piece.
Old time member on here hb32.
https://www.hotrodders.com/forum/dai...er-516511.html
Old 09-28-2018, 03:41 AM   #12
Epiparkour
Very nice picture, here’s my 1930 pickup.
Old 10-01-2018, 04:54 PM   #13
Myself
Nice! Does it also have the 010 and 020 stamps above the oil filter mount? I've had several of the mid 70's truck blocks and they were all 4 bolt main with nodular cranks and VERY nicely centered cam bores.
Myself is offline   Reply With Quote
Old 11-04-2018, 03:12 PM   #14
Epiparkour
Yes it has a 20 above the oil filter, is there any differences between the 10 and 20?
350 engine build, casting numbers, identification
