Still plays with trucks
Re: Rethreading the Door plates
Another option is to use a Heli-Coil or a solid body type threaded insert to repair the stripped out threads. This way you could keep the stock 3/8-NF threads and not have to worry about the fasteners not clearing the hinges.
The solid body type would be preferred as they are retained with tangs that are knocked in around the perimeter after you thread them in place. They are more money but would never come out with the bolt which is a possibility with a traditional style Heli-Coil insert. I've installed literally thousands of these as an air frame fabricator and machinist for the Air Force. They are a great way to fix torn up threads in an old part.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
| Bookmarks |
