how to adjust the steering gear
what is the proper way to adjust the steering gear ? I have tried to turn it both ways and just cant get it to where it feels rite
4x4k30 if trouble was money i would have plenty |
![]() Join Date: Jun 2015
Re: how to adjust the steering gear
try this: https://youtu.be/W5Ck4eANgII
Just did this and found an 1/8 of a turn helped a lot. no where near rack and pinion feel, but better with less of a dead spot in the center.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
It's spelled out in the "Unit Repair Manual".
Basically, you are supposed to remove the gear from the vehicle and mount it in a vise. Using an inch pound torque wrench you rotate the gear at the input shaft and measure throughout the rotation. The baseline measurement is called the "preload" (or "ends") and is adjusted by the big nut surrounding the input shaft. It should be adjusted to 12 inch pounds. The measurement taken at the straight ahead location is called "overcenter" and is supposed to be 20 in lbs or so. It is adjusted with the allen screw with the locking nut, located on the cover. Or - you can just leave it in the vehicle and crank the allen screw like everybody else. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#4 | |
![]() Join Date: Feb 2004
i guess either way i will wind up replaceing this steering gear i found one that was off a 86 m1008 that i had .and i am just gona put it on and hope for the best.
the top nut adjustment is the "last" adjustment made, after tightening the top where the steering shaft hooks up. read the writeup in the manual, and do it right. my trucks drive like new when I'm done adjusting them by the manual.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
#7 | |
4x4k30 if trouble was money i would have plenty Last edited by 4x4k30; 09-10-2018 at 09:54 PM. |
That looks pretty bad. I have never had one anywhere near that loose. I'd be buying a new/rebuilt one
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
well I put on the m1008 steering gear it lasted about 2ft when the front seal blew out . I checked every thing when I first put it on let me tell its a real pain in the but to do it by ur self . the steering gear was not leaking at all until I got in today to drive it.
