Old member
I want to get the ramp truck a little closer to the ground. I have some idea's on how but figured I'd ask here as well for input.
I have 4/2500lbs bags and mounts along with a tank and 2 compressors. The first picture is what I would like to have when done are very close any way as far as stance. The look I want basicly. But I want it functional to haul with. So guy's what are my options. I think I have found a complete front end with disc brakes also. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Old member
Some more pictures of what it has under neath it now.
I figure I will take the bed off first and then start cutting and welding a notch in the back. The thing has like 15 leafs under it. ![]()
