Old 03-22-2016, 05:47 PM   #1
1972Blaze
Radiator Re-core - How much should it cost?
How much should it cost to re-core a 4 row OEM radiator (1972)? I am getting a price of $450. That sounds high to me. Thanks.
1972 K5 Blazer Cheyenne
1966 L72 Corvette Convertible
2016 GMC Yukon Denali
1972Blaze is offline   Reply With Quote
Old 03-22-2016, 06:10 PM   #2
Eddie H.
Eddie H.'s Avatar
Re: Radiator Re-core - How much should it cost?
I bought a new one for a lot less than that.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 03-22-2016, 06:19 PM   #3
1972Blaze
Yep, a new one can be had for much less. I would not re-core this one for $450, but before I run it around town for more quotes I want to know if the $450 price is close to what someone should expect to pay.
Old 03-22-2016, 06:33 PM   #4
67Slider
67Slider's Avatar
I had my original re-cored and rodded for $80. Local radiator shop.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 03-22-2016, 07:22 PM   #5
truckdude239
truckdude239's Avatar
I was quoted almost 600 to do mine a few years ago i just got an all aluminum one
David fuller
Ase Certified Mechanic
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
Old 10-02-2018, 01:24 AM   #6
3757chevy
3757chevy's Avatar
Is that shop still open , We no longer have one in Canon City. And if so where are they located. Thanks.
'67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 10-02-2018, 02:48 AM   #7
72supr
I had one done this spring and it cost three hundred bucks.
72supr is offline   Reply With Quote
Old 10-02-2018, 03:32 AM   #8
toolboxchev
I have had one done over a year ago it was about 430 bucks. So not a bad price. Deal with mine was an industrial grade forklift core, its thicker material by a couple of thousandths.
The cores I am speaking of come out of Canada.
toolboxchev is offline   Reply With Quote
Old 10-02-2018, 02:33 PM   #9
rechinca
rechinca's Avatar
I just had mine quoted $350 for a 2 row in San Jose CA. I’ll be going aluminum.
1971 Custom/10 - 350/3 speed, Orange/White roof
rechinca is offline   Reply With Quote
Old 10-02-2018, 03:10 PM   #10
dagnabbitt
dagnabbitt's Avatar
I had a 2 core turned into a 3 core with restrictors for about $350, that's Canadian dollars though. I think $400 US is a little high, even for a 4 core.
I would recommend recoring to anyone thinking about buying new.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 10-02-2018, 04:06 PM   #11
Freddo
I was quoted between $350 and $375 to recore a two row core a while back. $450 may not be that far out of line for a four row core.
Freddo is offline   Reply With Quote
Old 10-02-2018, 05:19 PM   #12
rsavage
rsavage's Avatar
I just bought a new 4 core copper/brass radiator for $397.30 with all new brackets and pads from LMC including shipping for my 69 Blazer restoration. It is a nice looking stock unit. I had a stock 3 core that would have undoubtedly needed to be worked on. Did the same when I restored two other trucks and my GTO's. I like new and stock appearance, especially with the cooling system - new hoses, water pump, thermostat, fan clutch, and a good shroud.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 10-02-2018, 06:09 PM   #13
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
If they recored it, why did they have to rod it out?
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 10-02-2018, 06:28 PM   #14
hjewell2
hjewell2's Avatar
mine was recored cost was $538.00 4 row core Michigan
hjewell2 is offline   Reply With Quote
Old 10-02-2018, 09:36 PM   #15
82C10step
It's expensive because there are limited suppliers for the cores now. What ever you do don't throw that 4 row away. The tanks are worth money. Someone will need them for restoration at some point. They don't reproduce them.
82C10step is offline   Reply With Quote
Old 10-02-2018, 09:41 PM   #16
1972RedNeck
1972RedNeck's Avatar
Now you didn't. They either rodded out the original cores, or they recored it.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 10-03-2018, 01:27 AM   #17
vics stuff
I had found a place in California who still built the factory Harrison radiators With me living in Alaska and moving to Reno Nevada , I opted to not spend the $350.00 for a recore and $425.00 for some knock off cheepo , I went to this company in California and for a Desert 4 core radiator with automatic transmission fittings delivered to me here in Reno was under $400.00. Just had to round up some big block upper radiator brackets and I was golden. The truck runs all day long at 190.
Vic
vics stuff is offline   Reply With Quote
Old 10-03-2018, 09:09 AM   #18
jabborabbo
jabborabbo's Avatar
I think I paid about $100 about five years ago to have a radiator guy build a two row with proper tanks and a good core (see thread here).
Radiator shops are dying out though....
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense
jabborabbo is online now   Reply With Quote
