![]() Join Date: Sep 2014
What is this part for my 68 C20?
I think it may be a brace or something around the battery area but it has been long enough I can't remember
Re: What is this part for my 68 C20?
It's for this
I couldn't add more than a picture at a time for some reason.Thank you. Blake |
Old member
Drivers side front fender brace I think. At least that's what it looks like to me.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
X2 on the brace
Thank you for replying so quickly!
Is there one on the pass side as well? I only have the one. |
Just the drivers side only was used to support the inner federwell where the steering shaft runs through.
Ha! I just checked that and you guys nailed it thanks so much!
Let's see more of that truck!
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
Small edge down and taller edge is up
Absolutely LOVE the color...
Thanks for all the great help guys. I have a new question.
Can anybody provide pics of how the rear fender gravel guards attach exactly. I have them bolted in temporarily but something doesn't seem right. Here is a couple pics so you can see what I am talking about. |
Wow, those pics turned and suck sorry.
Is this for real, because if it is, I just installed mine upside down last weekend.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
![]() Join Date: May 2010
Here is the correct installation of the brace.
#15 | |
#16 |
Thanks First69 that's how I have them and your pics confirm.
I appreciate the fast response by all! Blake |
#17 |
Right, Wrong, or indifferent...I installed these pieces on my 72 and the tab that the red arrow is pointing at was tucked in above the lower lip of the bed side and the rolled edge at the yellow arrow was back behind the bedside as well.
I other words...You can not see the splash guard from looking straight at the bedside from the side. I'm not saying that mine are right because I have converted from steel to wood and they were a bit snug to install all tucked up in there. And, maybe it's a year specific thing, IDK...Just saying mine are different.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
#18 |
Wow, thanks for turning the pics! The spot welded upper portions are outside not tucked in. I ordered an assembly manual today so I'm going to wait and see if it shows where it goes for sure.
Blake |
#19 |
Well, after looking the fender brace over carefully there are witness marks that show the long flange pointing down towards the floor. I went ahead and installed it the way it was from the factory in case anybody was wondering.
Blake |
| Bookmarks |
