![]() ![]() ![]() ![]() You see, I wanted to jack the truck up a little bit. It had some whimpy 2" drops in the rear, so I found these moog load levelers for like $25 in the Summit Racing bargain pile (just down the street from me and I figured they would jack the rear up about 2" but instead they pumped it up 4". So that's cool, I like it riding high. So now I'm thinking I need to crank the front up about 2" and everything will be cool. So does it look fat or doesn't it??
Re: Do these rear springs make my truck look fat?
If you do end up going 2" up in the front, please post a good side picture. I'd love to see it. I have stock springs in the back and front on mine, and there's a pronounced rake. I often wondered what it would look like if I raised it 2" in the front. I'd also like to hear how you went about it, if and when you do.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
#3 | |
![]() Join Date: Jan 2017
"Do these pants make by butt look fat? No, your butt makes your butt look fat"
Al Bundy's reply to Peg I believe??? |
Those springs should settle an inch or more in a couple months of daily driving (say 2k miles?).
#6 | ||
The answer is always no, no matter what... !! Why nooo honey, they look fine!
![]() Join Date: Dec 1999
Are those the Moog 6101 or CC603 part number springs?
I also think a little weight in the back will smooth out the ride and your stance will be look just right.
Thanks for the info. I was looking at the Moog website and it shows the installed height on the CC603 is 10.75 inches and the installed height on the 6101 is 8.75 inches. The CC603 is a 'variable rate' spring and the 6101 is a more stock type spring.
I'm personally kind of disappointed because I have a set of the CC603 I haven't installed yet and don't really want my truck to sit up higher. The good news is I got them Amazon as Used, they packaging was just a little banged up. Maybe I could get a 2" lowering block? |
Nice truck
Ron
Member #111 68 C-10 Daily Driver70 4x4 Project76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
#12 | |
6082 3.68 0.75 722 2406 10 13.18 TG PT |
It looks like the 6082 is for the Front.
Your huge picture sure made your post fat. I had to shift right and left like a typewriter just to read it
. So you had 2" drop coils on, so going to stock would raise it 2". But you used coils that are intended to not drop as much as stock coils when weight is added which can mean they raise it a bit over stock, or at least the weight of the empty truck would not affect the stance. I'd think you'd have to add more than a little weight to make it lower since they are designed to not drop under load. Hence the name load levelerI don't think they'll settle for many years to come. Do all new vehicles sit an inch lower after a couple payments? Anything I have put lift, stock, or lower springs on sat the same as the day installed.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 10-07-2018 at 11:25 PM. |
#15 |
| Bookmarks |
