Old 06-18-2017, 04:31 PM   #51
Pontiac1976
Pontiac1976's Avatar
Re: Best Quality Dash Pad and Emblems
Desert_Eagle02: Does anyone know if the 81-87 defrost vent grilles will fit a '78 dash? I'm missing the original ones, and all I can find is 81-87
73-80 dashes do not have heater vent grills that why you can find any. Only 81-91 have the heater vent grills
This may be helpfull
http://bowtieguy.proboards.com/threa...ce-bezels-fits
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 06-19-2017, 03:02 PM   #52
Desert_Eagle02
Ok thanks for the info
1978 GMC K25
1984 Chevy Scottsdale K10 built 350 4"lift - SOLD
Desert_Eagle02 is offline   Reply With Quote
Old 10-08-2018, 09:57 PM   #53
raulb24
raulb24's Avatar
cheyenne dash looks good quality, anyone heard about OER or USA1 quality.
It's a lot of money to spend on a dash, if you had to choose quality & apparence, which would you choose between OER, USA1 or Cheyenne?
raulb24 is offline   Reply With Quote
Old 10-09-2018, 03:23 PM   #54
BigDooley77
BigDooley77's Avatar
Cheyenne Pick up parts seems to have the best fit of any.
BigDooley77 is offline   Reply With Quote
Old 10-09-2018, 04:36 PM   #55
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
EDIT: IT HAS COME TO MY ATTENTION THAT THE PAD I BOUGHT WAS ADVERTISED AS A CHEYENNE BUT IT NOT A CHEYENNE BRAND!!!! BEWARE OF SCAMMERS
I spent the money on a Cheyenne but after a summer of sun. It has deformed so much that I think I was my money. It didn't crack but both defroster ducts popped out and is extremely wavey. I think I'll take my original to a upholstery shop.....I was happy with it but it seems like the fiberglass backing can't handle the heat. I'm not willing to spend $300.00 plus a year. It's a great product as long as it doesn't see a lot of sun.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 10-09-2018, 09:47 PM   #56
1774btcrew
1774btcrew's Avatar
I hope they have improved these. I have dealt with them first hand and spoke with him a lot on these pads. They are hand made here in the USA. I will refer him to this post and see if he has any input
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 10-10-2018, 05:07 AM   #57
TKCR
TKCR's Avatar
He posted, but it was on another dash pad thread. I will post a link to that thread. Here it is. Anthony posted a comment, #21
http://67-72chevytrucks.com/vboard/s...d.php?t=762773
Old 10-10-2018, 10:50 AM   #58
1957 Chief
I have a dash pad from Cheyenne, the fit was perfect and I have had zero issues.
Bubba
1957 Chief is offline   Reply With Quote
Old 10-11-2018, 01:37 PM   #59
cheyennepickup
In response to the pad that got wavy after being in the sun and heat...
I believe this could be one of the dashes someone was selling using Cheyenne Pickup Parts name. I do not use fiberglass. Mine are made with ABS, the same material we use to make fan shrouds, so we know they are able to withstand heat. We have not heard of any of our dashes having that issue.
Last edited by cheyennepickup; 10-11-2018 at 01:42 PM. Reason: left out information
cheyennepickup is offline   Reply With Quote
Old 10-11-2018, 02:35 PM   #60
Ol Blue K20
I'm not sure where my girlfriend got it. I'll have to check but it was advertised as yours. That's why I bought it. I guess the first clue was probably when the left speaker pocket wouldn't go over the speaker. I'll edit my post, I don't want to bad mouth if it's not yours.
Dale
