Old 10-11-2018, 04:01 PM   #22
Jrainman
Jrainman's Avatar
Re: Reading A/C gauge
YOU can test the POA in the truck
TO test it idle at 1500 rpm
Use a fan and put it in front of condenser (radiater)
unplug the blower motor
gauge on low side reading should be between 28-30 psig
the POA factory setting should be 32 .
there are other things to check also , Air in system
make sure your heater core is not bleeding by
also spray water on the condenser and see if the lowside pressure drops.
Jrainman is offline   Reply With Quote
