Junior Member
![]() Join Date: Mar 2018
Re: Lift Help for 4x4 GMC
[QUOTE=jeffahart;8362093]Very interesting, How does it ride? Just curious. Anyhow, if you want to go back to an OE bumper you need the rest of the frame horn. Here's a picture of the front of my frame horns, you can probably find a better picture out there, this is one I have on file.
I've seen some funky stuff, that just might be a case of... ugly works! Anyhow, cut grind get stuff cleaned up for your new shackle mounts and get the frame horn tips. And get the proper lift springs. ![]() j Thanks for the advise. The ride is surprisingly good. How do I know what spring will produce the correct (same) lift ? Are horn tips readily available either oem or aftermarket ? |
#2 | |
![]() Join Date: May 2012
[quote=SangerV;8362111]
For the horns, you need to whack them off another frame. The bumper mounts snug to that horn and has braces from the ends of the bumper going to the frame. You need to finesse the horns on there so the bumper fits nice. ![]() j j
White K20 |
#3 | |
Junior Member
[quote=jeffahart;8362119]
and to possibly correct your wording .
the front is just the eye of the spring hanger . the shackle is in the rear under the cab . just ahead of the cab mount . do you have any pics of that area ? i think with the front all goofed up what might they have done back there . best to measure center of fender wheel opening now to ground . perform the rework and then re measure and order a set of springs for that amount of difference . it ride good cause there stock no lift springs by the looks of it . 2 good brand of lift spring for off the shelf is tuff country = good bang for the buck and great ride . then BDS = premium spring and top shelf stuff . most guys are super happy with just tuff country . now ruff country are stiff and lots of guys complain about the ride . i have removed there springs for people and swapped in tuff country .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
#5 | |
Junior Member
Junior Member
