10-12-2018, 07:49 PM | #1 |
Old member
Lights & voltmeter
I hooked up some lights for the ramp truck so I can see at night if I ever have to load/unload anything.
Plus I added a digital volt meter to keep a eye on the battery charge.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
10-13-2018, 12:22 AM | #2 |
20' Daredevil (Ret)
Re: Lights & voltmeter
Lookin good Andy, can't have too much light on a dark night. And after my recent electrical issues I can sure appreciate the value of a good voltmeter.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
10-13-2018, 07:50 AM | #3 | |
Old member
Just some more info: I ran the 12 volt wire for lights down to the solenoid I installed earlier for the winch & air compressor. I put a 40amp relay in it and just ran a wire off the fuse block to the switch to trigger the relay. Those bed lights are getting full 13.5 volts when on. If anybody ever tailgates me they will get a eye full!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 10-13-2018 at 07:59 AM. |
10-13-2018, 09:24 AM | #4 |
20' Daredevil (Ret)
Nice! How about a bit more detail on the voltmeter? Does it plug into the cigarette lighter?
10-13-2018, 12:29 PM | #5 | |
Old member
I bought 15 of them to install in golf carts. They read 0-100 volts 2 wire hook up. I put a cig connector on this one and use it in vehicles when I'm doing stuff but I decided to leave it in the ramp truck. I had it in the 56 while on the 2018 Power tour to keep a eye on the battery.
