Old 10-15-2018, 09:53 PM   #1
rcazwillis
71 Front Brake Hose
How long is a front brake hose for a 71? Napa hose was too short, data shows 11.5". Every vendor shows 11.5" I know the 71-72 hoses are longer due to tab location. Does anyone have a part number that worked on their 71-72.
Zane's 71 Build
rcazwillis is offline   Reply With Quote
Old 10-15-2018, 10:12 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: 71 Front Brake Hose
Call Inline Tube. Just picked up a set from them and they work well.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 10-16-2018, 08:51 AM   #3
Lanman1972
Lanman1972's Avatar
I think the 2 sides are different lengths. I also got mine from Napa and for what ever reason I had to switch them from one side to the other because the part numbers were not correct, or something like that.
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White
1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White.
Lanman1972 is offline   Reply With Quote
Old 10-16-2018, 09:40 AM   #4
GMCPaul
Well by measuring a new set I get one side is
12" from end of hose that connects to brake line to center of banjo bolt hole,
the other side is
12 1/2" total length from end that connects to brake line of hose to end of banjo fitting.
The 3/4 ton hoses are approx. 1" longer per side.
Sorry I don't remember whether the Left drivers side or the Right passenger side is the longer hose at the moment without checking that's installed.
Paul Jr @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 10-16-2018, 10:36 AM   #5
71meangreenc10
You cannot put the hoses on the wrong sides. The nuts on the metal lines are two different sizes. The last rubber lines I ordered from rock auto also for a 1/2 ton worked but they were from china. Are you putting these on a conversion or a 71/72?
Smitty
71 C30 Wrecker
Old 10-16-2018, 09:05 PM   #6
rcazwillis
Going on a 71. Foolishly disposed of old lines so can't compare. Napa part would not reach from caliper to hard line.
Thanks for measurements
Zane's 71 Build
