Old 10-16-2018, 09:51 AM   #10
fun in dirt
fun in dirt's Avatar
Re: 72 with 3/4 axles
Originally Posted by wingnut62 View Post
He wants the ride smoother and as I am not current on the four wheel hard core aspect of things, what shocks would you all recommend? Currently has a st of unmarked brushed aluminum cased shocks with external gas cylinders connected via a braided steel line....
Also he wants rear discs vs drums. Have found a couple options but not too many of course. Any advice welcomed.
Post up a couple pics of his spring set up now. Too much arch or alot of leaves will not help with a softer ride; height can be accomplished somewhat with hangers/shackle lengths. Unless they are super high dollar shocks, those fancy looking one usually are just that & are super stiff. I'd suggest some simple shocks that are correct length compressed & extended to match travel allowed by springs.
And like Mike said play with the tire pressure. Had a set of 36" TSL that I ran 14lbs in & now run 37" military with 22 lbs. Correct tire pressure has alot to do with the vehicles weight & footprint of tire tread.
For the disc conversion, this looks like a good kit. Have not bought it before (we used parts had laying around already), but have other parts from them w good results.
https://www.ruffstuffspecialties.com...yABEgIjtfD_BwE
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
3/4 ton, k5 blazer, shocks
