Old 10-16-2018, 10:33 AM   #1
sweetk30
sweetk30's Avatar
Re: Lift Help for 4x4 GMC
the orignal poster has not posted pics of the shackle end .
if this was only lowered on the front end and no other correction made as in lowered & or longer shackles or angled wedges under the springs to axle then i bet the caster is way off .
this could be a little bit good and a lot bad .
so yes it does look strong but if the rest of it was not addressed during this mod then there is prob a few other problems that need fixed to be 100%
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 10-17-2018, 06:21 PM   #2
SangerV
Junior Member
Originally Posted by sweetk30 View Post
the orignal poster has not posted pics of the shackle end . if this was only lowered on the front end and no other correction made as in lowered & or longer shackles or angled wedges under the springs to axle then i bet the caster is way off . this could be a little bit good and a lot bad . so yes it does look strong but if the rest of it was not addressed during this mod then there is prob a few other problems that need fixed to be 100%
May have found some frame horns. Here are pictures of rear shackle of front spring, and how it is block lifted in back.
SangerV is offline   Reply With Quote
Old 10-17-2018, 07:15 PM   #3
sweetk30
sweetk30's Avatar
o.k. rear shackle for the front springs looks stock .
the front only looks like it was lowered then to gain lift . kind of stupid i think for the reasons i said on front axle caster being way off . but anyway .....
try back to stock then go from there .
like i said before take measurements so you have height reference info before so after you know what you need to regain that height .
