Old 10-16-2018, 09:36 PM   #1
hugger6933
what is the best
way to remove the clutch pedal from the swinging pedal assembly? I.m changing my truck to auto and want to remove the clutch pedal and also add a wide brake pedal or at least the wide pedal foot part
hugger6933 is offline   Reply With Quote
Old 10-16-2018, 11:05 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: what is the best
The automatic transmission equipped trucks use the same pedal as that in the manual transmission trucks, as far as I know. I'd be interested in seeing what you end up with. But I won't be replacing mine.
~Steven
Simi Valley, CA
Old 10-17-2018, 12:04 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Easiest way is to remove the whole assembly as far as I'm concerned.....
Posted by Member "Palallin":
Be *REAL* careful futzing around with that assembly. Many years ago, I was pulling mine out, and the pedal arm got tapped, and the spring pulled it up over-center and lopped off the end of my finger in the process. That spring is No $#!+ serious.
LockDoc
Leon
Old 10-17-2018, 01:12 AM   #4
Sweeet67
Blow torch, unless of course you might want to go back in the future.
Sweeet67 is offline   Reply With Quote
Old 10-17-2018, 07:51 AM   #5
hugger6933
I have the whole pedal box out should have made that clear. My first thought would be cut the pedal of close to the top then tack it at the stop so it can't cause a rattle. Yes I know that the brake pedals are the same for both auto and man trucks I just thin k the wider brake pedal would look better
Old 10-17-2018, 09:18 AM   #6
rpmerf
rpmerf's Avatar
Would it be possible to grab a wide pedal (possible whole assembly) from a later year truck? Not sure when they went to the wide pedal. Might even be able to sell your pedal box to someone looking to do a manual swap.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 10-17-2018, 09:34 AM   #7
davepl
davepl's Avatar
I haven't compared on the trucks, but on the B body cars it's the same pedal box with a different pedal hanging in there, so all you need is the right pedal and maybe a spacer.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 10-17-2018, 10:19 AM   #8
LockDoc
LockDoc's Avatar
If you have the assembly out all you have to do is remove the arm that the clutch rod fastens to on the right side and slide the clutch pedal out of the bracket, shaft and all.... It doesn't affect the brake pedal.
LockDoc
Leon
Old 10-17-2018, 05:36 PM   #9
hugger6933
Lock Doc that is what I did. Once it was out I ground the pedal where it is welded on from the back side. I had several boxes from the 99-02 C1500 laying around so I cut the pedal off that brake arm and welded it to the brake arm in my 70 pedal box. I will be doing all of my trucks like this when I get to that part of the build. i really like the way the bigger pedal looks even though it is just the box assm sitting on a table
Old 10-17-2018, 06:11 PM   #10
LockDoc
LockDoc's Avatar
Good deal. Glad it is working out for you.
LockDoc
Leon
Old 10-18-2018, 02:07 AM   #11
OregonNed
OregonNed's Avatar
My clutch pedal was already removed when I got mine - the brake pedal and arm still attached as stock. I wanted the larger pad, so I went with the Lokar and I really like how it looks.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
