Old 10-17-2018, 08:23 AM   #1
CG
BlahBlahBlah
Cab Lights?
What year did the bumps for clearance lights first appear? Before that were the clearance lights factory installed or dealer installed?
Old 10-17-2018, 08:28 AM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Cab Lights?
I think the bumps started in 69.
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again...
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 10-17-2018, 10:01 AM   #3
davepl
davepl's Avatar
Re: Cab Lights?
I don't claim to know at all, but if you look at the motor vehicle safety standards there were major revisions, including adding side marker lights to cars, for 1967. That'd be my guess if I had to guess.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 10-17-2018, 10:31 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Re: Cab Lights?
Eric is correct. '69-'72 had the raised pods on the roof.
LockDoc
Leon
Old 10-17-2018, 11:04 AM   #5
CarolinaHD
Moderator
CarolinaHD's Avatar
Re: Cab Lights?
So 67-68 were they dealer installed or factory ?
Alex
1967 C50 292ci Lumber truck
1967 C50 292ci Dump truck
1967 C60 366ci Fire truck
CarolinaHD is offline   Reply With Quote
Old 10-17-2018, 01:19 PM   #6
LockDoc
LockDoc's Avatar
Re: Cab Lights?
I can't honestly say off the top of my head..... That's why I didn't answer CG's question on that.
LockDoc
Leon
Old 10-17-2018, 08:11 PM   #7
68panelman
68panelman's Avatar
Re: Cab Lights?
Both. For 67-68, If ordered, they were installed at the factory. Dealers also installed them per GM's instruction sheets. Yankee 77's were the model cab lights used in 67-68.
68panelman is offline   Reply With Quote
Old 10-17-2018, 08:13 PM   #8
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
Re: Cab Lights?
I have a 1967 CST with a Dec 01/66 production date and the U01 Marker Lamps on the SPID.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline   Reply With Quote
Old 10-17-2018, 09:06 PM   #9
CG
BlahBlahBlah
Re: Cab Lights?
I have an extra roof with the bumps and I have an NOS set of the yankee lights. Weird thing about them though is no rubber bottom, its a foam seal. Maybe the fella I bought them from took the rubber bottoms ... long time ago, oh well.
Anyway, just trying to decide what to keep and what to get rid of. Thanks for the help and I hope my question helped others out too.
Old 10-17-2018, 11:31 PM   #10
jocko
jocko's Avatar
Re: Cab Lights?
Personally, I like the look of the raised pad setup with cab lights, but, having said that, my inner geek would only add a raised pad roof on a 69-72 and would use Y77s on a 67-68. Y77s could also be purchased for install by the dealer or as a kit for the owner to install even after 68 - well into the square years, however those would not appear as a U01 on the SPID - only the factory ordered ones would be on the SPID (i.e. 67-68 U01 (Y77) or 69-72 U01 (pads)). I have a set of Y77s socked away somewhere, possibly for use on my 72, but I'm almost certain they had a rubber bottom gasket(??) - I'd have to check to confirm though. Here's a pic of the gaskets I'm pretty sure are on mine also for ref.
Old 10-18-2018, 06:49 AM   #11
Re: Cab Lights?
Yep, GM did what they had been doing for any +10k GVW trucks (think DRW/Cab & Chassis) all along through '68...just add the contoured base Yankee77 style. By '69 they came up with their own design integrated into the roof. Or more like integrated the roof into the clearance lamps 69-72. The same lamps went directly onto the roof with no modification 73-91 R/V.
Old 10-18-2018, 07:08 AM   #12
Chevyland
Chevyland's Avatar
Re: Cab Lights?
Keep the roof in your shop
And
The yankee lights on the shelf in your man cave
If
You don’t have Enough space,
Pm me. I’ll tell you where to ‘get rid’ of them.
Chevyland is offline   Reply With Quote
Old 10-18-2018, 08:28 AM   #13
CG
BlahBlahBlah
Re: Cab Lights?
These are the lights I have. Metal chrome base. I think the foam pad might have tucked up inside? But when you sit the light on it the edge of the foam just barely sits outside of the base. I believe they are in GM boxes too. Would love to have a set of the rubber gaskets, but good luck finding something like that alone without lights.
