20' Daredevil (Ret)
![]() Join Date: May 2003
Rubber Floormats -- Again
This gets discussed every so often.... hoping there's new (better!) info out there by now.
I haven't been able to find good quality, long lasting OEM-style rubber mats (with tails) for my high-hump '72 K20. Last ones I bought about 6 years ago looked good at first, but lasted less than 4 years before cracking, splitting, & dry-rotting. Has anyone found a mat that might be worth trying? ![]()
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#2 | |
The Older Generation
Re: Rubber Floormats -- Again
I haven't bought one lately either. The last one I bought for the Longhorn 4x4 a year or so ago was the worst one I ever owned. The truck has 352 miles on it and the mat has completely fallen apart. It Sucks.... LockDoc
Maybe if you put some 30lb tar paper (roofing underlayment) down before mat. Seems that my truck has some kind of tar paper on top of white foam then the mat.
Might help to keep from drying out. Just a thought Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
20' Daredevil (Ret)
Yessir. My truck has always had the white closed-cell foam pad laid down first, followed by a thick heavy tar-like layer (heavier than 30lb roofing), with the rubber floormat on top. When I installed the last mat, the foam and the tarpaper were both in poor condition so I got new ones and put them in. Darned if I can find the receipts though, so I'm not sure where I bought them. I bought the floormat from Wes, so I probably bought the underlayment materials from him too. But I don't see them on his website anymore, just the mat. Which is all I need, but the last one I bought from him is falling apart already, so.....
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
You might want to check with Wes again. He can tell you if he has found a better brand since then.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
I used the thick Poly Vinyl full mat and it still looks like new after many years . I know its not the kind of mat you are asking about but another option .
20' Daredevil (Ret)
I have seen them advertised but know nothing about them. Would you mind posting a pic or two? That would help me know what it actually looks like. Do you know if it uses the white foam / heavy black tarpaper sound deadener under the mat, same as a rubber mat does?
Also looking for something other than carpet
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
I cant post pics but can text some to someone that can post them .
![]() Join Date: Oct 2009
While not original equipment for a truck, I've used 65-66 Impala rubber mats from Impala Bob's. They have a good assortment of factory colors that match most of our carpets. Other years might work, but I just happened to have some 65 Impalas in the past. They're subtle, think they have a small bow tie if I recall, all rubber, look right at home. Might be worth taking a look if you don't require original truck mats. Also - I have not used them in a high hump, so please check the measurements and make sure they fit your truck - I'm kinda working off a distant memory of using these...
![]() EDIT: I think these are the ones I used - notice they are wide on the inside (trans tunnel) edges so you can trim to fit right up to the trans tunnel. Avail in 3 shades of blue, dk green, red, fawn, black - one of the blues shown. I vaguely remember they wouldn't break up the car-set-of-4... Not cheap, but they looked nice in the truck, like a factory mat. There are year-specific ones also, recommend look thru all to see what works best, maybe not just these. These were a very heavy vinyl or rubber. http://www.impalas.com/1962-76-chevy...or-matset.html Last edited by jocko; 10-16-2018 at 03:16 PM. |
#11 | |
20' Daredevil (Ret)
My 67 C-10 has the original rubber floor mat, still soft and pliable. Has foam and tar board and is super quiet. Truck is a 250 3ott that purrs like a kitten which helps greatly.
My 70 K5 has carpet that's glued down to the OE front and rear rubber mats (thanks previous dummy) I managed to get nice used front and back originals from the board with the intent to dump the carpet. I'm sure the original mats contain more natural rubber than the repros that fall apart in a few years I'll say it again "carpet is for cars!!!" But hey I can be a little bias ![]() |
![]() Join Date: Aug 2004
I think the high school build truck is using one of the full floor rubber coverings. It looks good from what was shown in the thread.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
You can always text them to me Flashed
#15 |
I will get some tomorrow .
#16 |
Here's pics of flashed mats
#17 |
20' Daredevil (Ret)
Thanks Dale & Flashed, that helps make my decision. I prefer the appearance of OEM-style rubber mats but can no longer accept their ridiculously short life, especially considering their cost. Those vinyl mats look just fine and since they apparently last quite a bit longer, that's what I'll get next time.
#18 |
This one has been in for about 6 years and looks like new when it's clean . I'm about to blow this truck apart for an LS Swap and once back together will get a good thorough cleaning . I have been so disappointed with the plug fouling ,oil burning crate motor I have not given it much attention lately .
#19 |
I, too, like the rubber/vinyl flooring, BUT what's the difference between the original style and the vinyl?...I'm missing something! I would have thought Flashed's flooring was the original style.
It looks like it fully covers the floor and contours to the floor as well. Is it just a different material? Vinyl versus rubber?
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
#20 |
It is vinyl and does cover the whole floor but is much thicker than the original style rubber mats . I plan on using another one in my 70 build .
#21 |
Bruce88 installed the molded polyvinyl mat. He has a good write up on it with some good pics.
http://67-72chevytrucks.com/vboard/s...318544&page=23 |
#22 | |
20' Daredevil (Ret)
![]() ![]() Also, OEM mats covered the front part of the floor, then just the outer edges were covered by the mat's "tails" going towards the rear of the cab.
#23 |
![]() Join Date: Jan 2012
Anyone figure out/find a source for the factory style thin white foam and tar paper that goes under the factory floor mat?
#24 | |
20' Daredevil (Ret)
"Front under carpet Factory style soundproof set made of original style tar-like material to deaden sound and absorb moisture to prevent rusting. Includes the white polystyrene top pad also. Exactly like original. This item has separate shipping charges as it ships oversized II Made in the USA"
#25 |
![]() Join Date: Apr 2016
How does somebody know what type of hump to order a mat for? When I was buying my carpet, I ordered it from Classic Industries, and the choices included low hump and high hump TH400. Since I have a TH400 I thought that means I need the high hump TH400 choice so I ordered it. There was enough room for me to add a 2x12 board under the carpet at the hump location, so I guess I got the wrong carpet. I like it anyway and now it appears I have a high hump with the board build-up. Are there 3 different hump heights with a 3 on the tree transmission and TH400 automatic are different or just two different heights in these trucks? When I wear out this carpet I think I will change to one of those vinyl mats like Bruce88 put in.
