Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-20-2018, 06:54 PM   #4
1Bad72C10
Re: 502 Twin Turbo
502 tt combo is nice make sure to get a nice cam for turbos as it will work better for the set up. the stock cam will work but wont drive the turbo's like you need. i'm having a 540 twin turbo built now with 9:1 compression with twin 83 mm bullseye turbos. real tame on pump gas around 1200 to 1500 hp on the street. c16 in it probably around 2000. i will never put c16 in but my engine builder wants to tune for it just in case lol. anyways it is very doable probably a set of 80 mm's turbo's and a small decent cam from either bullet, comp cams, or howards cam's will do you right and be realy friendly to whatever driving you plan on doing. as far as bridging the gap that's just fabrication work. I have a plazma man intake with a 5" throttle body and both my turbo's have 3" that im going to fab together to go into the intercooler which is 4" in and out. Once i get back up to the throttle body i will just expand it to 5" hope this helps
1Bad72C10 is offline   Reply With Quote
