Old 05-16-2004, 02:18 PM   #1
smitty62
smitty62's Avatar
Question Crankcase ventilation
I've got an old pair of the SoCal type valve covers that I'd like to powder coat and use, but they have no holes for a PCV valve or other crankcase ventilation. (I want to keep them that way). I've seen show cars/trucks with no evident ventilation holes in the valve covers. Any ideas on just how this is done? Is there a PCV valve hole hidden in some way?
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 05-16-2004, 03:00 PM   #2
walker
walker's Avatar
Older sbc's had the pcv valve in the back of the block. The original 327 that came in my pick up was that way.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 05-16-2004, 03:48 PM   #3
68C15
blood type; Retumbo
68C15's Avatar
that's a tough one. you would need some sort of vent. whether it be PCV or atmospheric. what kind of intake do you have? is there a hole in front for oil fill tube? if so get a cap with a breather in it. otherwise maybe somehow attach a baffle assy from a 70's style VC to bottom front of intake & put PCV valve through a hole in intake. just brainstorming here. any one esle have any ideas?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 05-16-2004, 05:39 PM   #4
john
member #16
john's Avatar
I have seen PCV's screwed into the oil fill tube on front of intake with a sealed cap.
john is offline   Reply With Quote
Old 05-16-2004, 07:49 PM   #5
BtnkBndt
Pennyless Fool
BtnkBndt's Avatar
I'll gladly take those covers off your hands.
Here, I have a pic of how my 283 is vented through the rear of the block. The valve is actually threaded to the carb or inline.
"Who owns this car with the peace sign, the mag wheels, and four on the floor?"
67 Short Step
283/TH400/4.11
BtnkBndt is offline   Reply With Quote
Old 05-16-2004, 08:23 PM   #6
smitty62
smitty62's Avatar
Yeah, I remember seeing those vents now. The valve covers had slits in them didn't they? They had to allow for air entry somewhere--was it the valve covers or elsewhere?
Smitty
Old 05-16-2004, 08:35 PM   #7
BtnkBndt
Pennyless Fool
BtnkBndt's Avatar
Air comes through the vent on top of the oil filler tube on the front of the manifold.
67 Short Step
283/TH400/4.11
Old 05-16-2004, 08:47 PM   #8
smitty62
smitty62's Avatar
Yep--I remember it now. But I'm still stuck as I don't want to run that oil filler either. The show cars I've mentioned didn't run them, so I'm still in a quandry as to how they do it.
Smitty
Old 05-16-2004, 09:05 PM   #9
neonlarry
neonlarry's Avatar
Why do you think they call them trailer queens, you don't need too much ventilation driving them on and off a trailer.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 05-16-2004, 09:13 PM   #10
Bowtie67
Bowtie67's Avatar
Unless you have the early style block with the crank vent or filler tube in the front of the Intake manifold your pretty much screwed, Of coarse there is another solution and that would be to have a machinist drill a hole in the back of the block to allow for some type of ventilation, without it you will be forcing seals to blowout to release pressure. If the Valve covers you have are original GM they are collectable for those guys wanting to turn there old cars back to original.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
